Question about Epson Artisan 800 All-In-One InkJet Printer
Black vertical line on left side of copy from epson artisan 800
Black vertical line printing on left side of copy
SOURCE: Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Posted on Jun 07, 2008
sherlyn c
  • 134 Answers
SOURCE: trying to scan to email on Epson Artisan 800
If you are scanning wirelessly, you have to launch the epson scan software from your computer and scan to e-mail from there. You can scan using either professional or home mode.
Please take note that scanning from the printer only supports direct connection, which means you have to plug in the printer to your computer via a usb cable.
If you cannot launch epson scan, please let me know. And include the operating system that you are using too.
Posted on May 03, 2009
SOURCE: lines on copy's when using auto document feeder
You don't say exactly, but I'm guessing that scanning when laying the document flat on the glass (ie, not using the document feeder) you get a printout that is fine. It's only when you use the document feeder that you get the vertical lines on the printout?
Epson repair tech in my area says this is a common problem. It is due to the aging of the calibration strip (the white strip at the underside of the flat bed glass near the "home" position). It shrinks after years and can't provide correct calibration.
This is a problem only with the pages fed through the document scanner. It sounded weird to me, but the tech said he stocks lots of replacement glass and does lots of these repairs to Epson scanners.
It might be cheaper to buy a new scanner rather than get yours fixed. He said it's pretty inexpensive to do this repair, but scanners are also pretty cheap.
Good luck.
Posted on Feb 03, 2010
  • 3 Answers
SOURCE: epson artisan 800 will not print
please make show that ur connection to the printer is correct.mostly if u using usb cable.uninstall and reinstall ur printer drivers can solve the problem.
Posted on Apr 19, 2010
SOURCE: black lines in pictures printed from Artisan 800
I have the same issue, It seems 1 line of pixels is overlapping with the next set of pixels and makes a dark line horizontally.
Posted on May 29, 2010
On Epson Artisan 800 the scanner leaves wide black stripes for the whole length of the paper. Printing From a file is OK.
If computer printing is fine (source) but scanner printing has problems, then of course, your problem is in the scanner. The only solution based on your info (which is good), are the lines in the same areas on other bad scanning prints? If so, your problem means that the scan-head has a connection problem leaving a 'black' send to the print buffer. This will require some technical repair replace or clean connection. Remember that this is a mechanical movement that not only records what it 'sees'e but at what X-Y location the read was 'seen'. It would be worth it to get an estimate from your local computer repair center give you an estimate.
Sep 22, 2014 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 810 prints vertical black lines on all documents
this problem is usually fixed easily. this commonly occurs when print head is clogged. I use a facial tissue and alcohol to clean the head with the ink cartridge in an upside down position (if possible) then i print one or two test prints to get it back to normal.
Jul 06, 2014 | Epson Artisan 800 All-In-One InkJet...
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
My Epson Artisan 800 prints only 1 inch of anything and then spits the paper out
Try the following to resolve this issue.
1. Check if same issue appears when using your Artisan 800 as a standalone copy machine.
2. Try printing from a different application to isolate the issue further. You can also print a windows test page to check if this issue is caused by the application that you are printing from or by the printer driver.
3. Reinstall Printer Driver.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
When using the copier a 1/2 inch black line on right side on top of the copy. Cleaned glass, no nicks just started. it does it with autu and manual feed.
Did yo clean the thin glass on the extreme left side. If you lift the document feeder cover, you'll see the thin glass strip. Make sure it's clean.
Mar 05, 2011 | Epson Artisan 800 All-In-One InkJet...
My Artisan 800 only prints the top inch of the page - the rest of the page is blank. This is true regardless of the function: print or copy or fax, so I don't think it's related to the computer. Ink...
My Artisan 800 was doing this and I realized it was because I was using three hole punched paper. I think the printer sees the top hole and thinks the paper has run out and cancels the rest of the page. Big engineering goof Epson.
Dec 17, 2010 | Epson Artisan 800 All-In-One InkJet...
Black lines in pictures printed from Artisan 800
Apr 23, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson artisan 800 will not print
Apr 19, 2010 | Epson Artisan 800 All-In-One InkJet...
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Artisan 800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
