Question about HP w2207 Monitor
When i log on to my windows profile the screen
When i log on to my windows profile the display will always be in the vertical position even if the screen is horizontal, but when others log on the displey is normal if you know how to fix this please help
  • 1,800 Answers
Try reset the display settings click right on the desktop
choose diplay parametrers.
Posted on Mar 13, 2009
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 15, 2013 | Samsung N120-12GW Netbook
Tip
Create a Hidden User Account This tweak allows an account that is...
Create a Hidden User Account This tweak allows an account that is normally displayed on the Welcome screen to be hidden from view. To log on using the account it's necessary to use the Log On To Windows dialog box similar to the one in Windows 2000 i.e. press CTRL+ALT+DEL twice.
[Start] [Run] [Regedit]
Go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\SpecialAccounts\UserList
Modify/Create DWORD Value of Data type REG_DWORD Named [Type Name of Account to be Hidden]
Setting for Value Data: [0 = Account is Hidden / 1 = Enabled]
Exit Registry / Reboot
While the account is hidden on the Welcome screen, note that the account profile will be visible in C:\Documents and Settings or wherever user profiles are stored as well as in Local Users and Groups.
on Jan 26, 2010 | Computers & Internet
Sony vaio laptop screen shows vertical lines upon booting then proceeds to windows loading with semi transparent vertical bars on background. Upon logging in, screen displays everything in a large scale...
the screen inverter is on its way out simple to replace unscrew the rim on the outside of the screen pull it off gently at the bottom there is a stip with wire going into it at each end disconnect it remove it do the reverse to put it in i suggest ebay for spares
Feb 11, 2012 | Sony Computers & Internet
When i log on the screen turns black
sounds like your lcd inverter or even your backlight, the inverter is the cheaper option , personally i would get them tested.
hope this helps
Jan 23, 2010 | HP Computers & Internet
My windows xp will log onto the welcome screen, but will not log
hi i am techbuddies from fixya group i want to give a try to solve your problem
first of all try to boot your computer in safe mode with networking and you can do this by pressing F8 on your keyboard for 10 times while starting your computer ,check that wether you are able to log on to your computer .if you are able to log in then try to take a back up of all your data and then try to create a new profile ,because might be possible the profile that you are trying to log on to on normal mode might have gone corrupted .
if it does not work please get back to me on fixya or on my email address ullekhtandon@gmail.com
i would try to take a remote of the computer and would try to solve the problem .
thanks
techbuddies .
Jan 18, 2010 | Computers & Internet
How do I change the default color profile? I have calibrated my NC-10 with a Spyder3 and the new profile is shown together with the ''srgb color space profile''. The problem is that when i restart my NC-10...
Instructions Download an icc profile above, then (in windows XP), go to display properties > settings tab > advanced > color management > add
Select the downloaded icc profile, set as default. You now need to reboot windows -
Jan 16, 2010 | Samsung NC10-14G Notebook
Good Evening, I have a HP laptop and it has a black line about 1 inch wide running vertically on the screen
To me this sounds like there is a problem with the LCD flat ribbon cable which connects the motherboard/mainboard of the laptop to the LCD screen. Does this vertical line always appear regardless whether you are in Windows? If so, then the cable
is either slightly loose or is somehow being pinched by the laptop hinge. Tap or press in the area above your keyboard to see if this goes away. If not, you may have to open up your machine and inspect the LCD cable.
Dec 04, 2009 | Dell Inspiron 9300 Notebook
Start up screens are off to the left.
There's nothing wrong with the monitor. Monitors remember the settings for different video modes, including horizontal position. The video mode used when the splash screen displays is a size almost every monitor can handle. Then the mode switches to whatever you've set once Windows finishes startup. As long as the display is normal once Windows is running, you really don't need to be concerned.
If you want to correct the problem, you need to put the monitor into the same resolution and use its menu functions to adjust the size and position. Try pressing F8 when the machine boots to get into the Windows startup menu. This will probably also be shifted, so you can adjust the settings while the menu is being displayed.
Apr 16, 2009 | Computers & Internet
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
HP w2207 Monitor Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
