Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
My 15" L7 from the top. the ruber cone, come off, like the glue was't stronge
  • 39 Answers
That means you either overpowered the speaker by playing it to loud, You used an amp that was way to powerfull, orif this is a new speaker it may be a manufacturing defect.  Do you have a warrenty?
Posted on Mar 26, 2009
My idq-15s were coverd with a tarp in my truck for about 4 months the foam seperated Iglued it with some silicone is that going to be ok ?
Hello
You have glued the lead wire to the speaker cone paper with silicone glue I assusmes. It will go for some time. Super glue is best. OK.
Jan 15, 2012 | Soundstream SPLX-15 15" Subwoofer Car...
REPAIR CONE TEAR IN 18"
If the tear is large, or the speaker cone is brittle because of age, you might be best off having the speaker completely reconed. There are companies that offer the service, or you can buy replacement cones and do it yourself.
For small tears (an inch or so long), you can glue a patch in place. I have used a piece of a paper coffee filter as a patch, and plain white Elmer's glue slightly thinned with water. Put the patch over the tear and use a small brush to spread a thin layer of glue over it. Give it a day to thoroughly dry and you should be set.
I have found this repair to be more effective on smaller speakers than on large woofers, though. The woofer cones are more mechanically active. But I patched a couple of 15-inch cones that had been punctured for a friend, and they are still playing after a year. So it can't hurt to try.
Jan 30, 2011 | Audio Players & Recorders
Hello, i have a kicker l7 15 and the voice coil has seperated from the cone. any advice?
Well, you have 3 options really,
  1. Send it in to your local sound shop for repairs.
  2. Replace the subwoofer.
  3. Attempt repairs with super strong glue.
Jan 19, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My 12 L7 the rubber came off the cone and doesnt hit as hard what kind of glue would fix my problem
Hi, Jr.
I'm sorry, but glue will not fix this problem. When the rubber or foam edge of a speaker breaks down or deteriorates because of age, it becomes almost like dust, which is why it cracks and then breaks apart and falls away from the speaker. The only way to fix it (besides replacing the speaker) is to replace the edge, or "surround". At this link, http://www.simplyspeakers.com/All-Foam-Kits_c_118-1-3.html, you will find a kit that you can buy to repair your speaker for about $30. The standard 12" repair kit will work if you have an 'angle cone edge attach' type speaker (see the bottom of the page for a picture of what this means). This page, http://www.simplyspeakers.com/speaker-repair-foam-edge-replacement-instructions.html, will show you step by step how to use the kit to repair your speaker.
Good luck, and please remember to rate my help.
Thank you for the opportunity to help you.
Oct 14, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Where can i get a mojo 15 reconed
You'll find out it will cost you way more to rebuild the woofer than to replace it.
Jul 29, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer cone come loose from outer ring
well you can glue it. i have done it in the past. i used the gel super glue and it held up for about 3 yrs.
Mar 24, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
I have 1 "12" kicker L7 and i got into a car accident. the sub works greath but the outer face has a crack in it.. its not big but i wanted to know what could i do to fix the problem
If the cone has a crack in it, that is USUALLY fatal, but you MIGHT try using the BLACK ABS plumbing glue to repair the plastic.
I don't know what you mean by the front face.
IF you mean the frame around the cone, I would grind out a groove (Vee it) over the crack and mix and fill with JB Weld. Paint to match when the material has set up and is smoothed a bit.
Nov 09, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Hi there I have a problem with my kickers. Subwoofer l7 15" is blow,I was wondering if there is a repair kit avaible for it or not?
The only Kicker woofer that has a replacement cone/assembly is the SoloX woofers. All of those have what Kicker calls it's SPARE which is a field replacement assembly. They're designed for SPL competitions.
Nov 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Db drive vs kicker
The Kickers are the way to go here- they move more air because naturally a 15 inch square has more area than a 15 inch circle- thus more air moved =greater spl =LOUDER. The only thing that might get some equality between the two is if the db drive round sub has a far greater xmax that is the linear movement of the cone from start to full excursion-IF the db drive has drastically larger xmax than it could possibly outperform the L7 because of greater cone excursion which also =more air moved=louder---- haha thats a tricky one but ya got me wondering too so let me know what you find out please-Ive always been a kicker fanatic so im probably biased towards their products-never heard nothing bad about db drive though either im in salt lake city i dont know of anywhere out here that even carries their products so i have nothing to reference by except kicker L7's kick asssssssssss
May 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer cone detached.
you need a strong glue that remind flexable
Dec 29, 2008 | Kicker CVR12 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
60 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
