Question about Imperial IFS50 Deep Fryer
Imperial Fryer Pilot Won't Light IFS50
The gas valve, thermopile, and high limit are new. This unit worked fine for about 1 month. Maybe bad thermopile again????
  • Anonymous Mar 27, 2014
    I have an imperial gas fryer when I light the pilot no matter how long I hold the button in the pilot goes out as soon as I release the button. I replaced the thermopile with a new one and am having the same problem. What would you suggest I try next. also all my connections are tight and sound wiring to all conections
    Sergeant:
    Champion:
  • 234 Answers
For sure if you got gas to the unit.The only thing to keep the pilot for working is hi limit,thermocouplen.One other thing is does this unit need power for it to work?
Posted on Mar 13, 2009
Pilot will not remain on Imperial deep fryer model ifs 40
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. Be sure that you have a good pilot flame. The pilot may need to be cleaned or adjusted. The thermopile is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Aug 12, 2014 | Kitchen Appliances - Others
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Pilot light wiil not stay
Check if the gas pressure is of rated pressure as stated on unit's nameplate.
Make sure that the thermopile is free of soot or any form of dirt, a clean thermopile will absorb as much heat from pilot flame as it needs to generate small amount of voltage to energize pilot and main valve coils of the gas valve.
The pilot flame quality must be good.
Hi limit must have continuity across its terminals when tested with an ohm meter.
Regards.
Jun 19, 2011 | Imperial IFS40 Deep Fryer
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Hi,i want to know wath is the oil's temperature when the deep fryer is off and if a can regulate the pilot? my deep fryer is a imperial fsi-50,thanks
I would guess about 120-150F for the oil. There is a screw under a cap on the gas valve that you can use to regulate the pilot, but this is not recommended. The flame must be high enough to heat the thermopile sufficiently so that the pilot will stay on and the main valve actuate. For better or worse, most gas fryers are designed to keep solid shortning in a liquid state when off and to safely melt it overnight. If you need the oiler cooler, say for filtering, I suggest just turning off the pilot.
Jan 22, 2010 | Imperial IFS50 Deep Fryer
Imperial fryer
Try to clean the pilot orfice,ive seen even though the pilot stays lit it doesnt have enough millivolts to energize the gas valve.Did you check the wiring really good?
Feb 08, 2009 | Imperial IFS40 Deep Fryer
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Nov 29, 2008 | Imperial IFS50 Deep Fryer
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Imperial IFS50
Hi, Probably the thermocouple. It will be right at the pilot light and hooks to the gas valve. The pilot heats it up to tell the gas valve that the pilot is working. If this is an electronic ignition, It will be the flame sensor still close to the pilot and will need cleaned or replaced. Hope this helps.
kstfas
Jan 10, 2008 | Imperial IFS50 Deep Fryer
Imperial IFS50 Deep Fryer Logo
473 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
