Question about Sharper Image Ionic Breeze SI719 Air Purifier
Problem On switch blue light blinking. No air coming through vent. Seems to not be circulating any air. Have cleaned all filters. When I turn it on it starts to circulate then I here a very faint scratchy noice the the light starts blinking and the air stops.
  • Rhonda Fatchett Aug 07, 2007
    Thanks so much it worked
  • jkitn Feb 02, 2008
    I have the exact same problem as Pugy. Both of my tabletop SI719 ionic breeze started this within minutes of each other! This occurred after the 1st time I cleaned them, however, I DID NOT CLEAN THEM ON THE SAME DAYS. I followed the instructions for cleaning. My instructions say nothing about the blinking light, fact the light is not what prompted me to clean them. One started making noise, so I cleaned it as the instructions say, it was fine. A couple days later the other started making noise, I did the same. Shortly after the 2nd one was cleaned it stopped circulating air and the light was blinking. I checked the other and it was fine. After a short period of time I walked by the purifier that was fine and it was blinking too! I have done what is suggested here and it has not helped. They are completely clean. When turned on they do exactly as Pugy discribes!
    Novelist:
  • 135 Answers
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Posted on Aug 05, 2007
I have this unit and the blue light was blinking even after cleaning. I took off the bottom plate (after unplugging of course) and checked everything by touch, there was a little dial that I turned with a tiny screwdriver, being careful to put it back in the same position. When I re-assembled it, it works fine now!
Posted on Apr 13, 2010
Finally a logical solution, I will give it a try
Posted on Apr 24, 2010
I did what sueilden said with the dial. It works now, but only on low. Which way is the dial supposed to point? It seems it only turns with ease not even 360 degrees before it gives some resistance and I am afraid i am going to break it. I tried it in several different positions and it works on low now but will go back to the blinking light if I turn it on high. Ideas?
Posted on Jun 20, 2010
Why does a red light on top of the ionic breeze GP S1750 blinks and does not blow the air
well i had the same problem at one time ..heres what to do... try turning it upside down and bang on the unit gently .not to break it and make sure you did not break the two strings behind the vents..
take out the bulb and clean the whole inside as best as you can..
and if that wont work unplug turn button to on pisitioin and then plug the unit inand hope for the best ... if all else fails go to amazon and replace the unit..hope that helps
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Jun 11, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
There is a red light on my filter. How do I clear this? It's the button with a half turn arrow with a vent looking item.
If you haven't remove and cleaned the filter, the light will not go off, until you do. If you already have, be sure the filter is properly reinstalled in the holder.
May 23, 2011 | Vicks V9071 Air Purifier
The blue light blinks
I believe that a blue blinking light indicates that the stainless steel collection blades need to be wiped clean. The unit uses these blades instead of a replaceable filter. Simply wipe them clean with a damp cloth and you should be ready to go!
Jun 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
Sharper Image Ionic Breeze  SI719 Air Purifier Logo
698 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
