Question about Pool & Spa
Wiring schematic for a hot tub pump
I have a hot tub that I thought the pump was no good . So I took the pump out and put an old one that I had laying around in. Well the tub is wired for 220 and I didn't pay attention to the fact that the one I put in was for a 110 volt tub. I have a 220 volt pumo to put into it but I don't know what wires go where on the pump. It is a Magnetek Century Lasar spa pump cat no, BN51 Part 7-182477-02 Serial no. BU7-18
2 Suggested Answers
  • 111 Answers
SOURCE: I have a century lasar spa motor 177803, I bought it to put into my small hot tub, what heater/controls are compatiable with this pump?
If you are looking for a stand alone heater here are a few options:
Brett Aqualine HT-1
Therm Products 5.5kW
The above heaters only have Thermostat's for temperature control. They also include hi limit & pressure switches, those two are safety devices to prevent an over heat.
OR
A Hydro-Quip CS500 system, can plug into a regular outlet. It also comes with a time clock & air buttons to allow motor control.
Posted on Oct 30, 2012
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
Brett Aqualine HT-1
OR
Oct 25, 2012 | Pool & Spa
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
The foam instulation in my hot tub cover broke from heavy water
Pretty hard to repair. If the outer shell is intact, just use it. You may open the cover and take the foam out, duct tape it and reinstall. Other than that, you have to buy a new one. Good luck...Lee
Sep 21, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Hot tub wiring
this has nothing to do with computer speakers. it is a hot tub wiring problem...
Jun 22, 2008 | Audio Players & Recorders
Pool & Spa Logo
83 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
