Question about Maytag MSD2758GEW
I have a Maytag MSD2758GEW side-by-side-
I have a Maytag MSD2758GEW side-by-side.. The Freezer side is fine, but the refrig side is not cooling... Any ideas or suggestions?
  • js120mhz Mar 29, 2009
    my freezer side working fine but the frige side isn't.
  • Anonymous Apr 12, 2009
    Freezer works great but fridge side runs warm (40-42). Defrost works ok, fridge air flow present when freezer is running, but the only way to get below 40 is to tape off one of the vents behind the ice makes and block open the damper controlled by the stat (for 32).
Freezer erator section fine, but refrig not cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Aug 18, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrig side not cooling....freezer side operating fine
Check that the damper vent that sends cold air from the freezer into the fresh food side is not blocked by contents. Check that the damper is opening to allow cool air to transfer. Put the fridge into diagnostic mode to check the thermistors.
Jun 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is not very cold. Freezer is not
Our side by side did the same, started because the cooling coils on the bottom (although cleaned regularly), still overworked due to build up of dust and especially pet hair. The heating coil in the freezer compartment which prevents ice buildup in modern (frost-free) units kicks on full time and the compressor can't compensate, thus your perishables start to thaw. Luckily we were still under warranty. hope this helps you at least start diagnosing the problem.
Nov 24, 2009 | Maytag MSD2758GEW
Maytag refrigerator side stopped working -freezer side fine #MSD2758GEW
SOunds like it is the FF(Freezer Fan) this problem is very hard to detect as the fan will turn, but not enough to circulate the air thru the freezer and refrigerator. The minimum cost to repair/replace the fan assembly is around $300.00
Jul 27, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
I have a 10 yr old Maytag side-by-side. Came home the other night and the Freezer was at 40F. What is the most likely problem
to start: make sure refrig is turned on and running. you hear the fan blowing inside the frzr compartment?
2.pull refrig out and listen for compressor running. is compressor running/humming away or are you hearing a humming sound followed by a clicking sound?if you hearing a clicking sound than mostly
is your relay on the compressor that went out. look for a smal device on the side of compressor w/two or three wires. part# 12002794 $32.00
also make sure there's no frost build on frzr rear wall.that's another problem
Jul 15, 2009 | Maytag MSD2758GEW
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Coil is Freezing Up
MWKT, did the service tech replace the adaptive defrost board? By your post it sounds like a defrost problem. Check out the pic, this is the adaptive defrost board. I find that the heater and bi-metal usually don't fail on these models and the board is the culprit. back
Apr 01, 2007 | Maytag MSD2758GEW
Maytag MSD2758GEW Logo
497 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
