Question about HP DesignJet 750c plus InkJet Printer
Back door cutoff switch broken
I opened back door toclear paper jam. now the switch says it is open
  • 10,865 Answers
Ok make sure the back door is fully shut.by opening it again and closing it firmly. If that doesnt fix the problem then unplug the printer and let it sit unplugged for 3 minutes. That will reset it.
please mark this answer as a fixya!
Posted on Mar 13, 2009
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what...
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
When i on the printer display show paper jam
Hi
First switch off your printer now open the door of printer and remove the paper that jam. checked any small paper pieces is there also removed...................now close the door and switch on the printer..
May 18, 2011 | Computers & Internet
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
HP Vivera printer won't print
Take the cartridge out and clean the head with dry cloth and reinstall than then try.
also go to menu on the printer and out it back to factory settings.
Kevin
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Brother HL2030 laser printer. Paper jam, single sheet in machine, I do not have instruction booklet. Paul Bentley
There are several sensor flags along the paper exit route, if
any one of these flags stick or have broken the printer will
take the paper so far then shows jam.
remove the drum unit first then the paper jam, look directly
into the printer to where the drum unit sits and check to see
if one of the flags is sticking up-rite in the centre area.Its spring
loaded so as you push it back, it springs forward again thats ok
Remove base paper tray:
The other flag is at the rear and can be accessed by opening
the rear door and then by opening the inner paper exit ***'y
you can then see the flag on the exit ***'y,this is also spring
loaded. If any of these are out of place/stuck or broken a paper
jam will always occur.
let me know what you find!!
mongrelken
Jun 07, 2008 | Brother Office Equipment & Supplies
Paper jam
Sounds to me like the paper jam switch is broken. Open the back door and look at the center where the paper feeds between the rollers. There should be a small plastic switch actuator sticking up, it probably got broke off.....
May 02, 2008 | Dell 1700 Laser Printer
Brother DCP-7020
Props to Profjake. I followed his advice and problem solved! Here is what I found out.
I had the "Back door open" error on the LCD panel. There is a "interupter" type of sensor that detects if the back door is open or closed. When the back door is closed a lever is pushed forward and blocks the interupt module. The lever that blocks the sensor was not reqching the sensor horizontally - it was too far to the left. The lever on the far right is part of a 6" rod that goes across the middle of the paper path. The rod had jumped out of it's "home" position to the left and it was bowed a little bit. I carefully re-seated the rod to by gently lifting it and moving it to the right into a slot 1/8" from where I found it. The error cleared immediately. The was most likely caused by removing a paper jam.
Once again props to Profjake as his advice led me to the solution.
Hu said that!
Oct 01, 2007 | Brother DCP-7020 All-In-One Laser Printer
HP DesignJet 750c plus InkJet Printer Logo
41 people viewed this question
Ben Johnson
