Leaks: loud noises
When the machine goes into the spin mode; it sounds like is going to take off. It also leaks from some where. I have checked the bottom and can not see or feel any wet areas.
  • 6,784 Answers
This leak is coming from the internal water inlet valve. the jet noise can be because a heavy load was inserted and it could also be a failing motor. most spin noises are normal with age but, if its extremely loud, its because of a bad belt or gear case.
Posted on Mar 13, 2009
Magtag MAV408DAWK washer is working, but horrible noise when Spin. Agitator works normally, though it has weak sounds, loudly horrible noise in Spin mode. All others are working well. What parts do I have...
Hello & Welcome to FixYa
The problem seems to be either with the brake assembly or the transmission assembly going bad and needs replacement. If the sound is loud then the recommended repair is replacing the transmission assembly however you can also check the brake pads, if worn out then they also need replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Maytag Washing Machines
Noise when spinning
the bearings are going bad must be replace.
or if ou are lucky check if there is any thing inside the drum , like asmall piece of metal,,,,,
Apr 04, 2010 | Indesit W 123 Front Load Washer
Noise in the spin mode on a Amana LWA50AW top load washer
Based on your description, it sounds as if your outer spin bearing is faulty. See link below for an illustration of the bearing. Special tools are required to replace this item.
Illustration provided by; www.repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-ALW480DA-%3d%3di549695&PartID=549695
Aug 07, 2009 | Amana ALW480DA Top Load Washer
Loud whining noise when my washer is spinning
could be two things
1) thrust bearing
2) transmission
Jun 11, 2009 | Maytag MAV6200 Top Load Washer
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool top load washer
Check to be sure inner tub is not spinning freely on spin tube. It can be noisy when this happens. When it's spinning and stops it may continue spinning for a bit when this happens. You usually need to replace spin tube, because the tabs that key into drive block for inner tub break off. Also replace drive block.
Nov 08, 2007 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
