Lg f1480tds fault code ae has comeup and it leaking
2 Suggested Answers
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
LG true steam inverter direct drive 9 kg f1479fds5 on a screen AE error what s happend
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, call a repairman!
Jan 31, 2017 | LG Washing Machines
Model Wt-h550. What does fault code AE indicate?
This error AE normally indcates a water leak,try tilting machine backwards or forwards 2 see if any water comes out from base of machine
Dec 22, 2015 | LG Washing Machines
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
How do i fix error code AE on LG washer/dryer f1407adsp5
Hi.
Error AE is prompted when there is a leak detected at the base of the appliance or when the anti flood safety device gets activated.
Disconnect power by unplugging power cord or resetting circuit breaker.
While power is off remove any water present at the base of the appliance.
If there is no water, check the pressure switch, wiring and control board for faults that may result in error AE. Check also setting of the drain hose at the back (it may cause siphoning), and make sure that inlet valve is not leaking.
Regards.
Ginko
Aug 28, 2011 | LG WM-2277HW Front Load Washer
My lg washer/steamer wd14756sd has the ae code on display. what does this mean?
Code AE is a water leak. There is a float sensor in the base of the machine for this. The likely fault is the lower bellows drain hose as they are convoluted and this catches women's hair pins...the machine vibrations and water in turn rust these which pierce the hose. Hose bellows part number for LG WD14756SD is 4738ER1008A. Be careful for other machines the numbers/parts differ.
Unfortunately it's tight room to replace the hose but it can be done.
Jan 16, 2011 | LG Washing Machines
What is the AE error code on LG steam direct drive washing machin
Dec 29, 2009 | LG Washing Machines
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
New LG Washer Dryer
Are you sure it's says AE for the error code.  LG doesn't list that particular error code.  Please check again.
Apr 19, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
