Question about HP w1907 LCD Monitor
My w1907 monitor is too dark to see anything without a flashlight
It was working fine last night, today it is so dark it's looks black. If I shine a flash light directly on it I can see it is working. I tried resetting brightness & contrast but neither had a effect. I restored my computer back to last week when it was working. Nothing, HELP please!
  • itezadoragon Apr 08, 2009
    Mine isn't so dark I can't see anything, but there it is definately darker than it was earlier in the day.
    THe thing is, though, my cursor is still white, but nothing that is supposed to be white is white. There also seems to be a blue kind of fram around my screen when it is black. (Not black like when I turn it off, just black when the screen is.)
    Problem Solver:
  • 10 Answers
Here is a replacement CCFL power supply. $75 USD
Replacing the part is at your discretion. You can also just ask a electronics savvy friend to do the swap.
Posted on Mar 24, 2009
Your backlight is gone. LCDs usually use CCFL (Cold cathode Fluorescent Lamp) for backlight, maybe it's your CCFL power inverter (power supply for the CCFLs) or the CCFLs themself.. You probably won't be able to fix that for yourself :(
Posted on Mar 13, 2009
I bought a new inverter, and it worked for a like 1 hour
and then the same happen black screen
is that the ccfl lamps?
Posted on Jul 21, 2012
My acer aspire laptop 5336-2524 worked fine until today when i turned it on everything works fine except the screen stays black. What can i do to fix this
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 01, 2012 | Computers & Internet
Gateway 5150 - computer screen stays black, screen works fine, just very very dark - can't seem to adjust luminosity?
Apr 09, 2012 | Computers & Internet
Cannt get my mini hp 1151nr to boot up only get black screen cannt get to windows
Black screen? So does it look like it booted up fine or did it shut down? Does it look like the computer is running, but the screen is black? If so, then:
Apr 02, 2012 | HP Computers & Internet
The camera still works but when its dark in the room nothing shows on the monitor. If we turn the light on it works. It seems like the night vision feature is broken. I covered what looked like the light...
  1. It should go to automatic night vision. If this feature is not working then the answer to will a flashlight work the answer is not very well. The light will have to be on the child and a flashlight does not have much light behind it. Perhaps if you put a small lamp on a dresser that shines on the area the child is, this may work enough to keep an eye on him/her. A flashlight not so much. Hope this helps.
Regards, Tony
May 25, 2011 | Summer Infant Day Night Handheld Color...
Monitor will come on, monitor status box will come on and then screen goes blank. How can I fix this?
rwhite97, If your pc is working fine with substitute monitor, and w1907 lcd unit does same (black screen, or blanknblack screen) when connected to a "known good" pc, then you should visit and read some stuff at this 2005 blog. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then learn the flashlight test and what it means. Then go to YOUTUBE for video clips on lcd monitor disassembly and lcd monitor repair if you are into do-it-yourself repair. Remember this!!! Your w1907 unit uses the same basic design and operation principles that ALL brands of ccfl back-lit lcd monitors use. Good luck with the repair. Come back here and leave comment after doing your research/investigation and then rate this response. 12fixlouie
Jul 16, 2010 | HP w1907 LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Sceptre X-24-wg LCD not bright dark
if you can see the image in the monitor the light tubes are not firing and this is commonly caused by blown capacitors on the power board, the capacitors need to be replaced and the monitor should work fine.
Let me know what you want to do .
Mar 22, 2009 | Computers & Internet
I have to push the power bottom all the time. If i don't, it turns off and the light indicator goes off not amber or any other color. Now that i'm typing i'm pushing the bottom... Last night it was working...
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 26, 2008 | LG Flatron F700P 17" CRT Monitor
HP w1907 LCD Monitor Logo
599 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
