Question about Frigidaire Dishwashers
No power in dishwasher
I hooked everything back correctly even grounded wire
    New Friend:
  • 35 Answers
Check the power first. Then post a detailed question :)
Posted on Apr 24, 2013
We sold our bosch dishwasher, working perfectly. New owners transported it on its back. Now it won't start, or even show that it is getting power, though the outlet works. What has happened?
Hello KT;
My name is Peter. I am a retired field service appliance technician.
Transporting the dishwasher on its back should not have been a problem. It is only with refrigerators and freezers that need to be transported up right, to prevent compressor oil getting into the refrigerant sealed system.
You may have a power cord problem. You have a 3 or 4 wire power cord. If you have a 3 wire power cord you need a 15 amp circuit breaker. If you have a 4 wired power cord you need a 30 amp circuit breaker.
The wall socket that you are plugged into my not have a ground.
You need to check the wall socket and the wire connects at the dishwasher. Send me a model number so I can see what you have. If you have a 4 wire connection you can chance the cord to a 3 wire. On a three wire you have a neutral and two hot with a small green ground wire. On a 4 wire you have a neutral two hot wires and a neutral in the center with a ground wire.
I would put my money on the wall socket not having a ground.
Send me a model number and I will help you.
Feb 07, 2015 | Bosch Dishwashers
I have power, its grounded, illumination, everything, reads my cds and ipods and even scans radio no problem but the problem is that i have ZERO sound from the speakers all wires are correctly hooked...
the pink wire is for amplifier and ur car must have one built in side under the dash or in the back or ur car or suv try to see if u might have one cause if it does not have power going to it ur speakers will not work i hope this helps.
Aug 17, 2010 | Alpine CDA-9885 CD Player
How do i hook up the ground wire on jenn air dishwasher model jdb1080aws
Attach the green ground wire to the frame of the device ... there should be a green screw close by the place you hook up the power.
Jun 13, 2010 | Jenn-Air 24 in. JDB1080AWS Built-in...
No power
You have probably missed re-connecting part of the electrical wiring- probably missed a ground connection..
Check you have re-connected:-
the main power supply via the fusible link (or in line maxifuse),
the battery negative terminal is correctly grounded to chassis/frame,
the motor ground connection to the chassis or battery negative.
Oct 09, 2009 | 1991 Ford F150
Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Feb 20, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
I am trying to problem solve for dishwasher that is properly installed and is not working or even responding to being hooked up electrically. My husband tried to wire it and unfortunately wired it...
no matter what brand it is the unit must have been hooked up power to ground to make a spark when turned on.
they dont have a fuse to protect them, but what may have happend is you could have shorted out a door switch.
be sure that you hae the wiring correct now and that your house fuse or breaker is on.
the wiring is very easy to hook up as black to black, white to white, and bare wire to ground.
i dont see how your husband could have done that wrong, but anything is possible.
recheck the power to the unit and just hope thats all thats wrong.
if you are sure power is good, then something in the unit has shorted out.
Jan 31, 2009 | Dishwashers
Grounding a figidaire dishwasher correctly. The model number is MD8122RFSO.
Hello ashlyn010507,
What exactly do you need to know about how your dishwasher is to be grounded? The national electrical code treats has dishwashers wired like any other appliance in that a receptacle ( like on your wall) is placed in the general area of the dishwasher and a power cord is attached to teh dishwasher at junction box internal to that dishwasher.. the cord is typically plugged into a 3-prong outlet which has a ground terminal. Otherwise... that is all that is required... If you are hard-wiring it ( as was done years ago) then a power feed is brought into a junction box internal to teh dishwasher and you would wire the hot , neutral and ground there).. Please restate your question if this information didn't answer you correctly..
Regards,
Rick
Nov 28, 2008 | Dishwashers
Replaced door module...replaced circuit panel under the back seat..replaced door window switches...getting power to everything...driver window works and i can't get anything else to work...just wondering...
I had the same problem and it was the black ground wire in the drivers door (window Switch) I cut the wire from the actual switch box and ran a seperate ground to a bolt in the door... I drove my aurora for two years like that and then it was something this simple maybe it will work for ya... check the ground wire (blackone)
Sep 04, 2008 | 1997 Oldsmobile Aurora
Rebuilt heads on 96 blazer 4.3 now no power
Check your neutral switch, its usually on drivers side on the back of stearing column .Its easy to reach and if you consult a mechanics service book, it will be alot easier to find and save you alot of frustration. Please rate this. Thanx.
Jun 05, 2008 | 1996 Chevrolet Blazer
Dishwashers Logo
47 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
