Question about eMachines Emachine T2245 Power Supply Replacement 300W
Emachine Wiring Diagram
I opened the case (for cleaning) and didnt realize that while cleaning a connector came loose. I have no idea where this connector should be plugged in. The connector type is P6 white in color with red, 2-black and yellow wires running to it. The connected end is attached to a squarish black flat part (of which there are 2 of them, one of them is marked "slave" on a 2" flat gray wire looking thing) both of those black squarish things has those same black, red & yellow wires coming from them. Hope you can tell me where this white P6 connector should go, as i can't find any visible 4-pins anywhere.
  • eMachines Master
  • 5,660 Answers
What a Marvelous person!
You have described a 4-pin Peripheral power cable, ('P6'),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
An IDE harddrive, of which the 4-pin Peripheral power cable example, is plugged into.
Another look at an IDE (PATA) harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136096
http://en.wikipedia.org/wiki/Parallel_ATA
However, I do not know if the flat IDE ribbon cable marked Slave, goes to a secondary Harddrive, or an optical drive. (CD/DVD drive)
Either way the point is moot. BOTH of those 'squarish flat black' units, HAVE a 4-pin Peripheral power cable to them.
Another hardware component, those type of power wires CAN go to, is a computer case fan.
However not ALL power cables have to be used. Sometimes there are extra ones. These are in case they are need later.
To summarize;
The optical drive, or drives; that you put a CD, or DVD disk in; can use a 4-pin Peripheral power cable.
(IDE/PATA optical drive)
Harddrive's can use a 4-pin Peripheral power cable.
(IDE/PATA harddrive)
A computer case fan may use a 4-pin Peripheral power cable.
Or the 4-pin Peripheral power cable you see, may simply be an extra one. One if needed in the future.
The eMachines T2245 uses a Trigem (Manufacturer), Imperial GLVE (Model name), motherboard,
http://www.ebay.com/itm/New-Emachines-Imperial-GL-VE-20021218-Motherboard-Socket-478-System-Board-/121098707716?pt=Motherboards&hash=item1c320ba304
Supports an IDE (PATA) harddrive, (Or 2 of them)
Supports an IDE (PATA) optical drive, (or two of them)
I DO hope you are following Anti-Static Procedures!
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static, BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open, empty computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Also I would like to add;
http://computer.howstuffworks.com/
http://www.hardwaresecrets.com/article/Anatomy-of-a-Hard-Disk-Drive/177
http://www.hardwaresecrets.com/article/Anatomy-of-an-Optical-Drive/179
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 24, 2013
  • joecoolvette
    joecoolvette Apr 24, 2013
    EDIT: "These are in case they are need later." Should be, "These are in case they are NEEDED later."
I need a wiring diagram for a Whirlpool water softener WHES33. When I removed the top to install it I found a loose green wire. I don't know if it's supposed to be loose or if it came disconnected.
I don't no where to find wiring diagram but the wiring is simple harness from board goes to sensor and micro switch there are two more wires going to board from power supply .green is usually a ground does it have a connector on end
Apr 30, 2016 | Whirlpool Washing Machines
Transfer case wiring
If you go to autozones website and make a free account, you can logon to that account and put in the year, make and model of your car and look for the free repair diagrams. They have the wiring diagrams. Then change the make and model year to the donor car and look for those diagrams.
Feb 19, 2014 | 2001 Dodge Durango
Rear view mirror was wire ripped off
U will have 2 isolate all the wires so they cant touch each other & the body work -steel - just use some electrical tape 2 prevent wires touching!!!!! Or open the door & look 4 the plug C if U can pull on the plug 2 disconnect it!!!! Good luck!!!!
Nov 23, 2013 | 1999 Acura TL
I need a W2040 motherboard wiring diagram
must be easier to move the hd to a hd-caseing and start transfer to a another computer......to much time-consuming.
Mar 27, 2012 | eMachines W Computers & Internet
I need the wiring diagram for emachine t5224 desktop pc
Do a Google search for " emachine t5224 manual", and get one. The manual should contain the wiring diagram showing how all components and cables are connected to the motherboard.
Oct 27, 2010 | Computers & Internet
I have a 99 buick century my drivers front blinker bulb doesnt work, the rear works fine my dash indicator doesnt work either ive tried the wiring diagram but didnt get anywhere any ideas?
change bulb in front if indicator doesnt blink or blinks fast if new bulb check socket connectors may have corrosion or damaged wiring
Oct 30, 2009 | 1999 Buick Century
Loose wires inside my t2958 emachine , need a schematic website
Most of the extra wire are for expansion purposes and since most computers have different accessories,a wiring schematic may not help at all.
If you are just talking about the wire from the power supply box,I can help.
May 10, 2009 | E-Machines (T2958) PC Desktop
Need2 know wiring diagram 4 power supply 4 a emachine T2642
Hi there
The power supply should be ATX 20pin connection and also a 4pin connector, look at this picture below so you know you have the power connections in the right places>>ba37bd3.jpg
On the top left of the picture, the big cream 20pin socket is where the 20 pin connector goes.
In the middle to the left you will see another cream 4pin socket is where the 4pin connector goes.
If your power supply does not have the 4pin connector the pc won't boot up, you will have to go out and buy one.
If you have all the connections right and the on/off button is connected to the front panel properly, take out the system memory, clean it with a clean, dry, soft pain brush and also clean the slots too, re-seat the memory and reboot the machine to see if it boots up.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | E-Machines eMachines Desktop PC
Connection of wiring to board
6a98a1a.jpg For the usb connectors you can follow the diagram above:
For the rest of the connectors I need to know the model number of your motherboard
Nov 23, 2008 | Computers & Internet
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
eMachines Emachine T2245 Power Supply Replacement 300W Logo
98 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
