Question about GE Dishwashers
Dishwasher not filling with water. It is not the float. GE PDW 8480 Dishwasher
  • jboooor Mar 14, 2009
    Water runs into the unit for a short time, and then I hear it stop halfway through that first cycle. This only happens after the first time I turn the water back on after turning the water off to the unit overnight. The second and third time I reset and start the dishwasher, there is no water flowing into the unit...
    It seems like a pressure issue in the water line / valves in the unit. Is this indicative of a fill valve malfunction? How much should I expect to pay for a fill valve? Where exactly is the fill valve located?
It could be the fill valve or that the power is not getting to the fill valve. Pull the bottom panel and find where the water line hooks up to the valve. There should be an electrical connector on the valve. First, listen when the dishwasher is at the cycle where it should be calling for water, to see if youhear a click of the valve opening or water running in. If not, and you have a volt meter, pull the electircal connector and check for AC voltage across it when the dishwasher is off - it should be 0, and when the dishwasher normally would fill - it should be something above 0 - it might even be 110v. If the voltage is ok, but the valve is not working, you need to replace the vavle. If the voltage stays 0, then something is wrong in the timer/control circuitry.
Posted on Mar 13, 2009
  • ray fixit Mar 13, 2009
    A follow on - first, before you do the above, check to make sure that the waterto the dishwasher is turned on. There is usually a shut off valve somewhere in the water supply line.
GE dishwasher model number GHDA480N10WW doesn't fill with water.
check the float switch usually located in the front right of the dishwasher it should move up and down freely sometimes crud will get under the float and hold it up so the dishwasher thinks its already full.
Nov 02, 2013 | Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
My portable dishwasher won't fill? Please help!
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 20, 2011 | GE Dishwashers
Not getting water
Hi
Daniel
Nov 27, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I have a GE mokel PDW 7300 dishwasher. I recently
Hello. Disconnect the dishwasher drain hose from the disposal and look into the disposal tube where you will see a plastic plug that you will need to knock out with a screwdriver and a hammer. Regards, J.
PS kindly rate my answer. Thank you. Joe
Feb 07, 2010 | Dishwashers
Dishwasher turns on but no water is going into the dishwasher it is a GE potscubber 970
As there is no water entering the machine, check ;-
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
No Water
The first thing I would check is the water float. The float is located on the bottom left front of the dishwasher floor. You will see a float cover, remove the cover and make sure the float moves up and down with your fingers. It should move freely.
If the float appears good, you will have to remove the lower kick plate. Behind the plate you will see the float switch and the water fill solenoid valve. With a volt/ohm meter you can check the float switch and water fill solenoid for proper resistance.
If you feel you want to persue that, we can get more specific about resistive values.
Let me know.
Regards,
Aug 13, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Nov 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
131 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
