Question about Cameras
DP-MCR4 Windows 7 OS - HP Pavilion computer - won't recognize hardware inserted.
BillB-SA
  • 2761 Answers
SOURCE: HP PAVILION a6000n with lightscribe supermulti drive / cd writer
If it fails to recognize and CD or DVD that's inserted you will need to reinstall the driver for your LightScribe. The factory drivers for your system can be found here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3548643
If it fails to recognize just one CD or DVD, chances are that the disc is defective.
Posted on Dec 02, 2009
Testimonial: "TURNS OUT IT WAS A HARDWARE DEFECT. PLASTIC WORM GEAR WORN ON TRAY DRIVE SHAFT AND WAS NOT POSITIONING THE DISC PROPERLY. THANKS FOR YOUR HELP."
parrotheadpc
  • 2600 Answers
SOURCE: i wnt sound driver for hp pavilion dv1000 laptop
Make sure your laptop is set to update and change the settings so that it updates during a time when you will have the system up and running, or just go to the windows update site and click to update, windows will scan the system and hunt for a driver for that device. I have not had a windows 7 unit yet that did not eventually download all the drivers it has needed. Just leave it on and let windows update run.
Posted on Feb 03, 2010
  • 11967 Answers
SOURCE: my camera usb isn't recognized, i have inserted
Use a separate card reader to download your pics...it works every time.
Posted on Jun 26, 2010
stranger_ab
  • 133 Answers
SOURCE: OS failure
Since the OS is corrupt you may need to re-install the OS using the F-11 recovery.
But, before that there are a few options available for you.
Start your computer and keep pressing F-8. It will take you to the advanced boot options. There select Repair and press enter.
The recovery manager will start and will guide you to the repair menu after asking for administrator's password.
There select Startup repair. Cross your fingers and hope it works. If it works and windows starts up and is still corrupt, you may be able to move the data from your user files to some other location easily before recovering your system.
On the other hand if it boots cleanly, you will not need to format your windows partition.
But, if windows is not able to start, you may still be able to back up your documents using the Recovery manager and selecting back up your files.
Then you can re-install windows to give it a clean and fresh look.
It is advisable to use the internal (F-11) recovery because it will format only the windows partition and not the entire disk (which is true in case of recovery discs).
Regards.
Posted on Jul 20, 2010
dj_relly999
  • 4070 Answers
SOURCE: I have my Casio FA-28
Hi and welcome to FixYa!
Seems that the Casio FA-28 is not supported on windows 7 but works quite perfectly on xp. Updates are not even available. I'm sorry but I guess you'll have to settle on xp if you want to use the driver.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Dec 07, 2010
Dvd not working in bios or Windows 7
It's a common problem when upgrading a OS? Is the DVD rom the only component that's missing a driver? Any Unknown Devices? Have you opened the Device Manager and looked for the DVD? In Device Manager, Scan For Hardware Changes. Not Listed? Have you done ALL your windows Updates? All the HP updates? Try the driver here: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-58707-1&cc=us&dlc=en&lc=en&os=2093&product=3548266&sw_lang= Download the software and SAVE to a folder. Modify the compatibility of the software from Win 7, using this procedure: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/ BEFORE YOU START, CREATE A RESTORE POINT. With this procedure: http://windows.microsoft.com/en-US/windows7/Create-a-restore-point.
Jan 13, 2013 | HP Pavilion Computers & Internet
HP dv6745 cd/dvd rom drive isn't recognized in dev. manger but is in my Bios
hi
take your OS CD , insert into CD bay-- when prompted to , select REPAIR
this will correct any corrupted registry errors that my be found in your OS, which is causing the lack of recognition for the CDROM driver
good luck
Jan 03, 2012 | HP Pavilion DV6745US Notebook
Dv6-2150us webcam
Your new camera driver is simply not compatible with the 64 bit version of windows. Get a camera that is specifically designed with a driver for Win 7 64 bit version.
Sep 03, 2017 | HP Computers & Internet
System won't recognize downloaded driver, I have installed an update provided on HP's site, but it still won't work. trying to install on a windows 7 computer. had installed it earlier on a...
When downloading a printer driver from HP you will need to ensure that you are selecting the correct OS (eg. Windows 7) and the appropriate version (eg. 64 or 32 bit operating system). These drivers are different and using one on the other will not work.
Windows XP drivers also will not work properly in a Windows 7 environment and the majority of Windows XP drivers are 32-Bit.
Sep 06, 2011 | Office Equipment & Supplies
I have hp pavilion g20661 's CPU and it windows edition is windows 7 ultimate, i don't have the drives for windows 7 and i couldn't find driver in internet?
I suspect that this is a very old PC and you will not find any drivers for this model as this would not have shipped with windows 7 ultimate, i located the model on the HP website and it shipped with XP.
Unless HP supports the OS for that particular model then you will have to look for third party drivers.
Aug 31, 2011 | HP Computers & Internet
Hi, I have an old (1995) but absolutely perfect HP Deskwriter 600 Printer which was initially used for a Mac OS 7.0 computer. At that time printers according to Mac policy were ready made for use of only...
HP's site shows driver downloads for OS 8, OS 9 and Windows XP 64-bit. Unless the Windows driver will work with Windows 7 (unlikely) or Windows 7 already supports it, you're going to have to replace your old Deskwriter. There isn't anything you can do otherwise.
This is the same kind of problem many people faced when XP was new. Since the operating system was so different, much older software and hardware was no longer compatible. Some hardware makers came out with updated drivers, but others didn't. Either their hardware wouldn't work at all with the new OS or they figured that it wasn't worth the time for a low-cost item (especially true for printers).
Aug 07, 2011 | Office Equipment & Supplies
Can't download and install printer driver HP Deskjet 1220C for window 7
There is no downloadable driver for this printer. You just need to update the Windows 7 list on your computer with the latest update. Here are the instructions from hp:
The drivers for your HP product are already included in the new Windows 7 operating system! You do not need to download drivers to use the product . Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product. With the in-OS The driver located in the Windows 7 operating systemdriver, some of the buttons on the product do not function and some of the advanced product features are not available. For more information about your in-OS driver, and to see workarounds for lost functionality, go to our Frequently Asked Questions below. Install the Windows 7 in-Operating System (in-OS) print driver When you connect your printer to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Step one: Install the in-OS driver Follow these steps to install the in-OS driver in Windows 7. NOTE: The computer must be connected to the Internet for Windows Update to detect and install your product.
  1. Turn the product on.
  2. Connect the USB cable to the printer, and then to the computer. Figure 1: USB cablec01704933.gif NOTE: When you connect the USB cable to the printer, and then to the computer, Windows 7 activates Windows Update. Windows Update searches online for the most recent product driver on the Windows Update site. If the online driver is more recent than the driver stored in Windows 7, the computer downloads and installs the updated driver.The Windows Update process takes place automatically. Therefore, you might not notice that the process is in progress.
  3. Windows 7 detects the hardware and automatically installs the correct driver. A notification displays on your computer to let you know when installation is complete.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use workaround procedures instead. See our Frequently Asked Questions section below. Step two: Print a document Print from any software program to make sure your printer is working correctly.
  1. Open a document in the software application in which it was created.
  2. Click File , and then click Print .
Jul 26, 2011 | HP DeskJet 1220c InkJet Printer
Can windows XP be install on HP Pavilion dv7-1132nr with Vista OS
Yes, You can dual boot Windows XP and Vista but you'll be having problem finding drivers if you install Windows XP on this computer since Windows XP supported drivers aren't available on Hp download page. HP has only Windows Vista and Windows 7 drivers for this System.
Hope this helps.
Good Luck.
Thanks for using FixYa.
Jun 13, 2011 | Computers & Internet
HP calls my HP Pavilion dv9417cl Notebook PC a "Vista PC" and will not support it after I upgraded the OS to Windows 7. Nvidia doesn't appear to be of any help either. windows auto update keeps...
You should of used the Windows 7 Advisor before upgrading to Windows 7 from Vista. The advisor will indicate the hardware and software updates and changes you'll need before performing the upgrade. If you've already installed Windows 7, you can go to the Microsoft Update page and see what kind of updates you need for Windows 7 to work in you laptop. Also, go to the HP website and check the drivers download page for your computer with Window 7 installed, download the drivers, and then install them one at a time for each device. You won't need to talk to a human to do this.
Oct 31, 2010 | HP Pavilion dv9417cl Notebook
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
Cameras Logo
203 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
