Question about Whirlpool Kitchen Ranges
WHEN WE TURN OVEN ON, IT DOESN'T LIGHT RIGHT AWAY AND WHEN IT DOES, IT MAKES AN EXPLOSION AS GAS HAS ENTERED OVEN
    President:
  • 331 Answers
Kathy,
This is a common complaint and, luckily has a simple solution. I'll start with the solution and (if you're interested in the "why" of it) conclude with the cause.
First (solution)... your oven igniter has failed.
Second (cause)... Your oven utilizes a "glow" type igniter. In order for it to glow, electricity is applied and the current flowing through it causes it to get very, very hot. This electrical current is monitored by a device called a safety valve. This valve is programmed to open up main gas flow to the burner manifold after the igniter "flows" 2.6 to 3.2 amps.
Igniters are tricky little guys. Unlike a light bulb (which is either good or it's bad) igniters get "weak". So what happens is the igniter gets to 2.5, then to 2.59 then to 2.62, then back to 2.5 amps. It goes up and down. But the 2.62 amp "flow" was enough to open main gas, but not enough to ignite it. So there it goes... up and down. All the while the main gas is opening and closing, but not being ignited. This gas accumulates. Then finally, the igniter reaches it's ignition temperature.
That's when you get the explosion. The "whoosh".
It's not that difficult to replace the igniter (since I don't have the model number, I can't give you an exact part number, but it'll be either the round style or the flat style.
PULL THE OVEN OUT SLIGHTLY, REACH BEHIND IT AND UNPLUG IT!!!
Tools required:
1.) 1/4" socket or nut driver
2.) Flat or Phillips screwdriver
3.) Pliers
4.) Wire cutters
5.) Wire strippers
Remove the racks and then remove the "floor" panel of the oven. Then remove the diverter panel (might be a 3/8" nut or a wing nut... use the pliers here). Basically, you disassemble the bottom of the oven. You may need to pull the lower drawer out. Again, without a model number, I can't be specific.
After you have gained access to the igniter...you'll see that it's attached to the main manifold with two 1/4" screws. Word to the wise, here... use a little bit of liquid dish soap on the threads BEFORE trying to un-screw these. This will lubricate the threads and keep them from stripping. If you don't heed this warning and they strip? You'll have to grind them off in order to get the igniter removed.
Wire cutter time... snip the 2 white wires about 3" from the base of the old igniter. Wire stripper time... strip those 2 wires about a 1/2".
Now the old igniter is out. Pull out your new igniter. Cut any extraneous stuff off the END of the wires then strip them about a 1/2". Now mount the new igniter to the manifold (where the old one came from). Now take one wire (doesn't matter which one) from the new igniter and twist it to one of the wires you cut and stripped while removing the old igniter. Then use one of the ceramic wire nuts (included with your new igniter) and twist it on the exposed wires clock wise. Make sure there is NO WIRE EXPOSED after doing this. If there is, remove the wire nut and cut a small amount of you twisted wire pair off.
ALL OF THE EXPOSED WIRE SHALL BE INSIDE THE WIRE NUTS.
Do the same thing for the other wire. Now tuck all of the extra wire away. At this point, you're ready to test your handywork! Set it to bake and watch her light up!
All that's left to do now is rebuild the lower oven, grab a coolada and get some cookie dough. I'll be over at 6:00 for snacks :-)
Posted on Mar 13, 2009
  • Tracy Farrell
    Tracy Farrell Mar 13, 2009
    You don't have a gas leak. Don't freak out. Trust me, it's the igniter. Also... you don't have to turn the gas off to do this job.
    Another thing. I know that my description of the repair seems daunting, don't worry. If you are even a little bit handy with hand tools and are safe with them, it'll take an hour to an hour and a half at the most. I charge ~$215.00 for this job, btw.
    I can smell the cookies already!
  • Whirlpool Master
  • 3,361 Answers
Call an appliance technician right away.
You have a gas leak.
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
I turn on the stove and about a minute later it shakes the side of the house and lights. Heats well and works fine after doing this. It's a kenmore and about thirteen years old. What could be happening.
There could be expansion issues with the oven. When the oven heats up the sides or bottom could be flexing causing this. If it is a gas range with an oven igniter it could be the igniter is getting weak and the gas is not lighting right away and causes a small explosion when it does light. If it has an igniter look to see how bright it is. If it is orange in color it is probably the problem. They should glow a bright yellow. If the igniter has never been changed it could be the problem. Hope this helps.
Feb 17, 2014 | Ovens
Kenmore c970-657084
Explosion from what? If this was a gas explosion then you should have a professional look at it. If this was a power supply issue then you will have to replace the power supply board.
Dec 02, 2013 | Kitchen Ranges
Oven sounds like a bomb when turned on
The oven burner probably is rusted out, and the gas doesn't come out close enough to the pilot to light right away, so.....boom. Burners are not expensive, and may even be easy to remove. Be patient, and use a flashlight to look for mounting screws.
Nov 26, 2013 | Kenmore 72620 / 72621 / 72624 Gas Kitchen...
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
MY GAS OVEN WON"T TURN ON, IT MAKES ONE CLICK AND YOU CAN SEE SOMETHING GLOWING IN THERE BUT DOESN"T COME ON
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 18, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Gas oven bulb hanging inside + can i safely use this oven?
Sparks ignite gas. Sparks are usually present when switches are turned on and off (usually at the switch - not at the bulb).
Don't turn the light on/off while you are trying to turn on the oven. Once lit, the light can be turned on and off without fear of an explosion.
The big issue is melting the wires near the base of the bulb when the oven is hot. Get it fixed.
Mar 20, 2010 | Ovens
Small oven explosions
check and replace your gas regulator to your burners in your oven
Mar 16, 2009 | Thermador P304CS Gas Kitchen Range
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Kitchen Ranges Logo
796 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
