Siemens washing machine display panel not working (no display)
Display panel not working on siemens wm14s392gb - no display but other switch lights on. We had to pull the emergency door release cord (bottom right hand corner) to release the door following removal of trapped item in the detergent pump (now all clear). Why is the display not working. Thank you.
  • 4 Answers
SOURCE: Whirlpool Front loading washing Machine
Try checking the brushes in the motor.
Posted on Dec 13, 2008
  • 85 Answers
SOURCE: WASHING MACHINE BLOCKAGE
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Mar 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Posted on Jun 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: cannot remove pump cover on front-load Siemens S16.76
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
How do I switch off the child lock?
Which model Siemens washer do you have? For the WM16Y792GB, the child lock is toggled on and off by pressing and holding 2 buttons that are below the LCD display screen on the left side of the screen for 3+ seconds. The phrase "Child Lock 3 seconds" is just below the buttons. The temperature and spin buttons are above the display in the corresponding location.
For the WM12Q391GB, the child lock is toggled on and off by holding the Start button for about 5 seconds. On this model, the Start button is the one to the farthest right. This button doesn't seem to have a symbol or text indicating that it also controls the Child Lock feature. The manual does tell how to toggle the Child Lock feature on and off.
Many Siemens appliance manuals are available from their web site. Some are available here: http://www.siemens-home.com/ie/customer-service/manuals . Otherwise, try to find the product site and click on the Downloads tab. The washers listed above both have the manuals on their pages. The WM12Q391GB page is http://www.siemens-home.com/ie/productlist/laundry/washing-machines/WM12Q391GB?breadcrumb=frontloaderwashingmachines . The WM16Y792GB page is http://www.siemens-home.com/ie/productlist/laundry/washing-machines/WM16Y792GB?breadcrumb=frontloaderwashingmachines .
I hope this helps. Otherwise, please add a comment with the model of your washer. I will attempt to locate the Child Lock information you need,
Oct 31, 2015 | Siemens Washing Machines
Siemens washing machine gets water but doesn't start cycle
CHECK THE WATER PRESSURE SWITCH, THIS IS WHAT SENDS THE SIGNAL TO WASH CYCLE TO BEGIN. U CAN OPEN PANEL AND REMOVE THE TUBE FROM THE WATER PRESSURE SWITCH AND PLACE ANOTHER SMALL TUBE INTO THE SLOT OR A STRAW SOMETHING THAT WILL FIT SNUGGLY THEN BLOW INTO IT AND KEEP PRESSURE ON IT AND SEE IF IT GOES INTO WASH CYCLE. IF IT DOES U HAVE A BAD DIAPHRAM IN SWITCH M, BE SURE TO HAVE THE WASHER ON WASH CYCLE WHEN TESTING.
Feb 20, 2015 | Siemens Washing Machines
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
F26 washing machine Siemens s1272
The F26 error code on the Duet washer is a door switch error.
Disconnect the unit for 10 minutes and plug back in to power.
Check the display for any kind of power indication.
If you have any leds of power indication, try adjusting the door switch.
May 07, 2014 | Washing Machines
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
Siemens WM14S392GB - error F61. Help to fix please.
Error E61 means that the door is locked but the sensor is showing as still open.
You may have a faulty door sensor.
May 07, 2012 | Washing Machines
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Sep 11, 2009 | Siemens WM14S794GB Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
