WINDOWS DRIVERS TRACK MOUSE hand track fdmg11
hothawk
  • 174 Answers
SOURCE: Drivers Disappear
Its a fight between 64 and 32 bit versions. Audio codec is not so compactable with your sound card sysaudio file You need an updated driver which is compact-able with direct x latest can solve your problem
Posted on Jul 19, 2008
SOURCE: 2007 jeep liberty drivers side
When motor is all the way up do you hear a rattling in the door?
Posted on Aug 08, 2008
  • 4 Answers
SOURCE: 2001 oldsmobile alero window off track,
first remove the door panel there are three screws that need to be removed first 2 under the inside door handle and 1 on the lower left hand side behind a reflector then pull off the panel it will be held on by push clips, once inside move the plastic weather bearrer to the side ,run the window half way down you should see 2 window holding brackets pull the window up so you can drop it in the brackets, first get some black window adhesive fill the brackets with adhesive put window in brackets and roll it up and leave it up for 24 hrs.If the brackets are broken you will have to replace the whole window motor assemly which you can get on line for 89.00 not the 250.00 at dealer and you can install it yourself its easy to do.
Posted on Mar 05, 2009
  • 337 Answers
SOURCE: drivers window is off track
Her is a link to help repair your problem.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528005fcc3
Posted on Mar 12, 2009
thehumble1
  • 137 Answers
SOURCE: Apple iBook G4 Track Pad (Mouse) not funtioning
I think the first thing you should do is make all updates. I know that in some versions of the iBook G4, the trackpad does not work after installing OS X 10.4 (Tiger) before you do the updates. Update your OS X first. secondly, does the button work? Does the trackpad show up in the System Preferences menu? (under keyboard and mouse). It's very unlikely that the trackpad came unhooked unless someone has opened up your computer. If they have, there is a really good chance that they didn't plug it back in, because it's a hassle and easy to forget.
Posted on Apr 17, 2009
Mouse arrow shows but won't move with touch pad or button
Hi Wayne ,
If it fell off the edge of your bed last night it is likely that you have damaged the mouse track pad in some way.
you might have to order a new one off of ebay and have someone fit it for you !!
Or it might be as simple as the ribbon cable in the track pad has come loose and will need to be refitted.
can you see the movement of the track pad in the right hand bottom corner of the screen when you move the mouse with the track pad and by using an external USB mouse to get to the desktop?
Dec 29, 2012 | Dell Latitude D810 PC Notebook
Will trackball model 64215 work on Windows 7?
The last operating system that allows a Kensington Expert Mouse 5.0 Model 64215 to work properly is Windows XP. Kensington refuses to update their MouseWorks software in order to make it compatible with Windows Vista or 7. The mouse WILL work, but only with basic functionality, i.e., no programmable buttons, and the pointer moves crazy slow...
Jul 05, 2011 | ACCO Brands Kensington Expert Mouse...
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
The scroll bar on my HP pavilion zv5000 does not work.
no. not scroll bar.
you are posted that your desired pointing device
is bad,dead, and the do not want the built in device working,
your unnamed MOUSE is bad. right.
ALPS tells us nothing. (is it a GP-410UB " wild guess.
is it USB mouse or PS2? what model mouse? the number.
what OS are you running, we can not guess this... and matters. big time.
there are 2 issues on notebooks, zv5000
1: SHUTTING OFF THE INTERNAL ,POINTING DEVICE(S)
do that in device manager, click unwanted device
and click (right) PICK DISABLE .
it now dead this internal, pointing device.
2nd: option to is click Mouse (CP) and then pick the internal
laptop , mouse, and find a tab there called.
what to do with 2 mice, (on mine it has , USB mouse shuts off internal mouse, not all can do this, my HP8540 you can't but the maker of the notebook pad had and upgrade from this pad, and now has this feature,)
ymmv, your mouse may vary.
2: The mouse external. what ALPS, is it USB or PS2
finding drivers for very old mice can be hard,
did you have internet connections when you plugged in this mouse? if yes, it will attempt to find a driver automatically (PnP magic)
next time say.
a wild example.
Im running Vista OS.
My glidepoint model, GP-410UB does not work right.
help.
the Control panel. 101
has a mouse icon
and a device manager icon
this is your only controls, besides REG hacks.
we can all those, all ways, but you need to tell the helpers, OS, and mouse model first. and if USB
May 25, 2017 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a 97 camaro rs it has power windows and they are both messed up the drivers side motor is good but off track so i can pull up or push it down with one hand easy.the passengers side motor is dead or...
it is much easier to replace the motors then to deal with having them off the tracks and chancing breaking the windows when you go over a bump you can usually find the window motors on ebay for under $20
Apr 29, 2009 | 1997 Chevrolet Camaro
Logitech mx518
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 22, 2008 | Logitech MX518 931352-0403 Mouse
Computers & Internet Logo
David Payne
David Payne
