We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual - any idaes what happened to it? We just purchased a top load Kenmore 800 washer machine. The machine fill up, but did not wash, it only operate on the spin cycle. Now it has stopped filling up with water. Itwill not fill up or or do anything except work on the spin cycle. the user manual is of no use. Any idea?
  • 1 more comment
  • FRANWEST88 Apr 04, 2009
    We purchased a kenmore 800 in late January. Now it has stopped working and only works on the spin cycle. We just had a repair man come to see it, and he says it's the sensor. Because it is a new model, there are no parts available, and it has to be ordered. I have a large family. The part should come in about a week (we'll see about that) and then we will still have to schedule the appointment to fix it. I'm wondering, is there any compensation for having to go to the laundromat, spending money, and being inconvenienced for buying a seemingly worthless product? I'd rather exchange it for another model. Any advice?
  • prem mathew May 11, 2010
    If you are clear abt what the prob is we could solve very quickly. At the beginning you say "now it has stopped filling up with water" below you say "it will not fill up or......" I agree with you abt the manual being useless.
  • Bruno Coimbra May 11, 2010
    Well first of all, although it sounds silly,,, make sure the water valves are turned completely on, and there are no kinks in the hose's. This could be one of several problems. It could be that the timer is malfunctioning and not opening up the water inlet solenoids. It could also be that the water inlet solenoids themselves are malfunctioning. Either way, if you have only done 2 washes, it should still be under full warranty. I suggest contacting Sears, or Kenmore and try getting a service technician to go over to your house
  • 478 Answers
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
3 Suggested Answers
SOURCE: We just purchased a top load Kenmore 800 washer
8 out of 10 times the hose screens are clogged.  1. Remove the hoses from the back of the machine, but leave them connected to the hose bibs.  2. Remove the screen from the hose (it may be stuck at the back of the machine) (This is where deposits usually build up.) 3. Aim the hoses into the drum or a bucket and turn on the bibs. 4. If you don't have a full flow of water coming out of the hoses you will need to remove the hoses from the bibs and reverse the process. Good Luck.
Posted on Apr 30, 2009
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
1.- replace timer
2.- or motor has thermal fuse check continuity.
3.- replace lid switch
Jul 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Top load Kenmore 800 washer will not fill with water
Feb 23, 2009 | Kenmore 22422 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
Washing Machines Logo
535 people viewed this question
Top Washing Machines Experts
