My husband forgot to winterize our Kenmore Elite H3 washer when we moved. It was stored in our garage for 5 months(September - February). When we hooked it up water immediately started pouring from the bottom. I'm sure some part froze, cracked and is now leaking. I just don't know what steps to take to diagnose and fix the problem - any help would be wonderful.
  • saramehler Mar 17, 2009
    I took off the back and front panels and hooked up the water. It appears the water is leaking from the inlet valve itself but only on the cold side. I can't get around to see exactly what is going on or if something is loose. So my next step is to figure out how to take that part out and perhaps replace it.
    model 11045872404
  • 51 Answers
Its most likely the rubber tubing, and sack that connect the drum to the drain pump. You can either remove the back panel, or the panel in the bottom front of your washer to check for cracks in the rubber. It might be as simple as the tube came out of place during the move.
Posted on Mar 13, 2009
  • Bruno Coimbra Mar 19, 2009
    i believe you have to get a whole new detergent dispensing asembly which includes both the hot and cold water solenoids
Sour smelling kenmore elite h3 washer
This is pretty common. Get some front loader cleaner at the store
Nov 02, 2013 | Kenmore Washing Machines
Broked Spider on a Kenmore Elite H3 washer.
u can buy them seperatly. the shaft is part of the basket
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Where is the filter on the kenmore elite h3 washer
There is not a filter per say, but there is a coin catcher in the pump assembly. remove the bottom panel and it will be right in front.
Oct 17, 2009 | Kenmore Elite 45986 Front Load Washer
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Owner/operations manual, Kenmore Elite
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 24, 2009 | Kenmore 44832 Front Load Washer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
F/DL means the door lock.  If you take the bottom panel off (there are 3 screws), you can reach up and pull down on a lever to release the lock.  Next you need to take off the top of the washer (there are 3 screw on the back).  ONce you have the panel removed, you can see the wires and where they plug in at the back right area.  If you just jiggle them, you can get it to work again.  I am doing this right now until I can get a new computer.  My neighbor has a front loading washer of a different brand and experienced the same problem I am having now.  She is the one who told me how to fix it.
Oct 12, 2007 | Kenmore Elite 45986 Front Load Washer
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
