Question about Dynex 4-Port 10 Mbps Ethernet Hub
Ive got a dsl modem a xbox 360 and a computer i pluged in a internet cord to the hub from the modem and it only apears as 1 2 3 or 4 but dosnt under col why is that?
  • 153 Answers
The hub is showing you that a network connection is present. The LED that says Col indicates when collisions occur. In a blatant attempt to avoid explaining how ethernet networks operate, suffice to say that no collisions is a good thing. Some collisions is tolerable and normal, and a lot of collisions indicates a problem and can bring your network to its knees. Don't forget to turn networking on in your xbox.
Posted on Apr 22, 2009
Have one ethernet for computer want to use xbox live so i take out the ethernet from computer and put it in xbox unplug wait plug back in turn still will not connect red x for modem
You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
So it is modem to router wan port
Xbox 360 to router lan port
Computer to router lan port
You can purchase one cheaply at best buy
look at this link
Jul 29, 2009 | Microsoft Xbox 360 Console
Cant play xbox live
if you have any passwords on your internet make sure that those same setting and passwords are put into your xbox settings. It does not matter if it is wired or wireless the settings still need to be set to get any connection.
May 27, 2009 | Microsoft Xbox 360 Arcade
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
360 powerblock works when not pluged but dosnt when is plugged
It is the power brick. If you are under warranty you can have microsoft send you a new one for free, otherwise a new powerbrick is around 80 dollars.
Feb 06, 2009 | Microsoft Xbox 360 Console
Cant hook up xbox 360 to internet
does this help it sounds like you are puting your cable in to the 360 and the modem you wont have a internet ligth on untill you try to connect the 360 to go live you must reset the modem
Jan 23, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
Jun 18, 2008 | Microsoft Xbox 360 Console
Hello taz1028,
In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
Agent Xiong
May 31, 2008 | Microsoft Xbox 360 Elite Console
Xbox to compter
Path #1:
if you want to play online, with other people i am assuming? then what you would want is xbox live. you do have to setup a stable internet connection in order to connect to the internet*. and also you do have to pay a membership fee in order to stay in xbox live.
* and if you want to connect xbox live, you need a cable or dsl connection, either you need an ethernet cable or a pre-tuned wireless usb that is made only for the xbox 360. and also, you would need a cable/dsl company that is accepted by xbox live. and then go to the xbox 360 dashboard, then, click "join membership",
Path #2:
setup an ethernet connection either directly, or with a router/hub, then go the system settings, and click, "computers" and then click connect. but this path way is only to create a connection to the computer.
Jan 07, 2008 | Microsoft Xbox 360 Console
Dynex 4-Port 10 Mbps Ethernet Hub Logo
250 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
