Question about Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
Error code f2 cycle does not complete clothes do not drain keeps repeating spin cycle but clothes still soaked
    President:
  • 1,294 Answers
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Posted on Mar 13, 2009
  • 51 Answers
An error code F2 on the Whirlpool Duets usually has something to do with the drain pump not working, or working slowly. I also have a front loading washer (from kenmore) and if im washing clothes that hold alot of water like towels,,, once it starts to spin, so much water is released that it stops, pumps out the water again, and restarts the spin. If your drain pump isnt working,,, im assuming it will just keep retrying to complete a spin cycle.
  • Bruno Coimbra Mar 13, 2009
    an error code F2 on the Whirlpool Duets usually has something to do with the drain pump not working, or working slowly. I also have a front loading washer (from kenmore) and if im washing clothes that hold alot of water like towels,,, once it starts to spin, so much water is released that it stops, pumps out the water again, and restarts the spin. If your drain pump isnt working,,, im assuming it will just keep retrying to complete a spin cycle.
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
When the WP model WTW6600SW0 completes the wash cycle the clothes are still soaking wet. We have been running the clothes through another spin cycle, sometimes a second spin cycle to try to get the water...
You need to access your fault codes...pick any button but start or cancel and do the diagnostic test.
Press and hold for 4 seconds/release for 4 seconds and repeat this sequence till all the lights come on.
Press that same button to toggle thru the 5 most recent faults.
Post the fault codes back to me here.
Oct 16, 2012 | Washing Machines
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Washer does not complete its cycle on any wash cycle. Error Code F 02 shows up before rinse and spin is complete. Clothes are soaking wet. What is the problem?
check the drain hose for any blockages or kinks and check to make sure water passes through it freely. it may be that it's just not emtying quick enough and therefore clothes remain wet. in a worse case scenario the pump itself could be faulty :(
Oct 27, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
1,227 people viewed this question
Dan Webster
Dan Webster
Sal De
