Question about Poulan Garden
Oiler not working (poulan 2300 av)
How can I get it a part to work on it?
thanks Elgin
Fog Horn
  • 17 Answers
SOURCE: Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
Posted on May 26, 2009
SOURCE: have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Posted on Aug 04, 2009
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Thanks, guys. Right, I do fill it partially now, but it's annoying. Oh well, there is no simple way to restrict the line - I have disassembled the unit and one would only hope the designers would think about a simple device for adjusting oil flow, but there is none. Primitive, since oil will flow at very different rates in cold and warm weather...
Posted on Aug 16, 2009
dontbother10
  • 2220 Answers
SOURCE: I need to change an chain oiler pump in a poulan 260 pro chainsaw
A Poulan "PP260 Gas Saw Type 6" IPL example follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for the oil system and detail is sketchy at best; components are listed but may be on different illustrations. They are very useful during disassembly/reassembly.
http://www.ordertree.com/modelinfo/PWE/PP260-Gas-Saw-Type-6/75.PP260-Gas-Saw-Type-6.1.59.1.html
The oil pump detail is on the "Handle, Chassis & Bar Assembly" page.
Your saw has an outboard clutch, the oil pump is behind it. Use this as guide for clutch removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If your saw is not a Type 6 the correct IPL can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 09, 2010
  • 48 Answers
SOURCE: Auto oiler
The oil filter needs to be blown out, as well as the bar and behind the bar as the feed is just an open canal on the saw side of the bar. On your model their may be a guard that needs to be removed to access where the pump assembly comes out.
Posted on Apr 22, 2010
Testimonial: "I assume the oil pump is located behind the sprocket. Having trouble getting sprocket loose probably need a special tool.... Took the plastic 90 out."
How does the oiler work on a poulan micro xxv
The oiler operates off the crankshaft under a cover behind the sprocket. Find the oil port near the back end of the guide bar where the oil pump injects the oil onto the chain. That port could be plugged. Your little Micro probably does not have an adjustable oiler but just in case invert the saw body and see if there is a + and - in the casting just under the sprocket. If so, moving the slotted adjustment towards the + increases oil flow.
Sometimes sawdust enters the tank when being filled and plugs up the inlet to the oil pump. Keep an old 1" paintbrush with your oil can so you can brush away the debris before opening the oil tank to fill while in the woods.
Sep 23, 2014 | Poulan Micro Xxv Vintage Chainsaw Coil...
Poulan 1950 woodshark
The first thing I would look for are cracks in the oiler lines. If the saw has a manual oiler try to see if that will get oil to the chain. Check to see if the cap on the oil tank has a plugged vent hole.
Aug 30, 2013 | Garden
Chain oiler for poulan 2300 seems to dump all the oil out at once within minutes of usage
there is a seal between the pump and the case if that seal fell or wore out it will drain out of there
Aug 16, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2375 oiler not working
sound like you need to replace the pump
Apr 13, 2012 | Garden
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 2300 Firewood chain doesn't oil
She is long of tooth. Some oiler parts are NLA. Item 17 on the "Power Unit" print is the actual oil pump. Do not mistreat it; do not blow it out with air; they are no longer available.
http://www.ordertree.com/modelinfo/PWE/2300AV-Gas-Saw/75.2300AV-Gas-Saw.1.59.1.html
Please see this thread, post 5
http://www.arboristsite.com/showthread.php?t=120981&highlight=poulan+xxv+oiler
The *.pdf is your oiler. I suggest you read the entire thread. and save the *.pdf to your hard drive. HTH
Lou
Feb 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Have poulan woodshark, the chain oiler is feeding
Aug 03, 2009 | Poulan Garden
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi
It is gear driven oiler and there is not any adjusment for it.
regards savumihai71
Dec 11, 2008 | Garden
Garden Logo
496 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
