Question about Garden
Newholland tractor tc 25
TC25 NEW HOLLAND WILL NOT START. WHEN KEY IS TURNED ALL YOU HEAR IS A BUZZING SOUND IN THE AREA OF THE IGNITION SWITCH. TRACTOR WILL NOT EVEN START USING A 200 AMP ENGINE START.
rockitman187
  • 2559 Answers
SOURCE: Craftsman 15.5 lawn tractor (917.271061) won't start
Here is a link to the manual wiring schematics on page 31
Please rate this a fixya
Posted on May 21, 2009
  • 77 Answers
SOURCE: have 1975 Merc 115 h.p. motor. won't turn over with key
it may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
Posted on Jun 23, 2009
  • 202 Answers
SOURCE: Have Exmark 52 LazerZ with Kohler ch25 engine.
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
GM Elec
  • 1000 Answers
SOURCE: difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Posted on Aug 21, 2009
Can you tell me the year a Ford New Holland tractor/ backhoe serial number c642774 was manufactured? Also do you have a part number for the thrust bearing for this model tractor? Thank you!
Hi Susan:
It is unlikely that a FIXYA person would have the bearing that you are looking for, However, I would suggest that if you were to use Google to locate the dealer or service rep in your area (or even the nearest farm equipment dealer), you will be able to get the information that you are looking for.
Here is a link that will allow you to do a parts search.
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::home
Cheers
Mar 04, 2016 | Garden
Ford Tractor 5610S Key Switch Diagram
The parts diagrams for Ford tractors are available from the New Holland Parts Store: http://partstore.agriculture.newholland.com/us/ . I see a pair of 5610S tractors listed when I search for that model number. You can use the year of manufacture or location of sale to make sure that you are looking at the correct parts diagram. You want the Electrical Systems diagrams for the electrical switches and battery cables, for tractors sold starting 12/93. Part 6 is the ignition switch; part 8 is the key.
The wiring diagrams are also in the electrical systems section. I hope this helps. If you are looking for something other than the ignition system switch, please add a comment to clarify the parts for which you need diagrams.
Jul 13, 2015 | Ford Garden
How do I time
Are you sure that you are talking about a computer. Sounds like a New Holland Baler( a hay packaging machine). Timing of the knotters!!
Sep 20, 2014 | Cell Phones
Belt drive diagram for ford rt5
Exploded view of rototiller available at New Holland website.. Area with decals has belt path diagram.
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr55011ar111419
Belt goes around motor pulley and tiller pulley and above idler pulley, which is in the middle. When putting belt on, it is easiest to put around motor pulley first and tiller pulley (the large one) last. Belt is 3/8" x 27" v-belt. Idler pulley is available too, only under Lawn Boy part number, which is found on parts list at New Holland site. Just had to perform repair. All parts found on ebay.
Hope this helps!
Rob (Sterling Heights, MI)
Mar 21, 2013 | Garden
New holland TC33DA won't start
Sounds like a bad starter. Try giving it a few good taps while turning the key. Sometimes they can get warped and get stuck. Had to start my car for weeks doing this till I could afford a new one. Could also be the solenoid too but im not sure if it would even click if that was bad. Good luck.
Oct 19, 2012 | One Step Ahead New Holland Tractor Set
2002 yamaha v-star 650 turn ignition switch on and hear a buzzing sound
One of the replays is failing, remove the plastic trim and you will be able to feel the one that is vibrating.
Mar 13, 2012 | Motorcycles
When I turn the key in the ignition I don't hear anything and my car won't start. I tested the started and it is fine. I replaced the ignition switch. Could it be my alternator or my neutral safety switch...
no. the noise you're not hearing is the fuel pump. When u turn ur key on you should hear a buzzing like sound from the rear of the vehicle. If not, and ur car don' start, probably fuel pump. Just to verify the faulty fuel pump, have an assistant open the fuel tank cover and remove the gas cap itself. With you inside turn just the key on, and have your assistant listen for the "buzzing" or "hummin" sound. if nothing there, then faulty fuel pump. If noise is present, then perhaps you have a different problem like nothing is reaching the engine, fuel wise. Like a plugged fuel filter. when replacing the fuel pump, ALWAYS do the new strainer as installing the old one could cause a whole new set of problems and eventually wipe out the new one as well *RULE OF THUMB, WITH NEW FUEL PUMP, REPLACE FUEL FITLER.* this will be easier on the pump output to the engine. good luck.!
Aug 24, 2010 | 1994 Jeep Grand Cherokee
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
