Question about Sony SLV-N750 VHS/S-VHS playback VCR
Sony VCR ''Eats the Tape'' Model SLV-N750. It plays and records but doesn't release tape. It does not repond after I try to run forward or back and does not advance on ''Play'' but shuts off. Is there any hope?
  • 111 Answers
If this unit is 4-7 years old then TOSS it. As time goes by the rubber gets soft and the units timing gets whacked. Repair will be more than what it's worth , unless your emotionally attached to it ...
Please rate!
Posted on Mar 13, 2009
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
Aug 18, 2014 | Sony SLV-N750 VHS/S-VHS playback VCR
Our Sony Video cassette recorder model SLV_N750 won't play??? The tape is going into play, but the reels are not turning. The VCR starts with a snowy picture and guickly stops and won't play?
The problem is the idler assembly or the black square belt that drives it, this will cause the vcr to shutdown preventing tape transport. The vcr will need to be dismantled for repair, I recommend a tv technician to check your machine with an estimate.
Jan 08, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Intermittent loss of video (mimicking dirty heads symptoms)
Control head dirty. That is where the tape counter picks up the frame pulses.
Jan 18, 2018 | Sony SLV-N750 VHS/S-VHS playback VCR
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Jul 11, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony slv 715ub no stereo sound on tape playback
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
May 13, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N750 sound problem
befor i give u answer of this Q.i m gona ask u some think to make sure u regulur tape is orignal recoding from company is not that means u recrder vcr out of alighnment on audio head chack that ....and hi fi system very sensetive about it,s audio head alighment ....or might u notice movie runs slow some time or fast ......if that kind problem u can't do much about it only u can do use the orignal record tape or alighment a audio head ...good luk...oh yaa clean head first ..
Dec 21, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
338 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
