Question about Panasonic PV-GS39 Mini DV Digital Camcorder
Horizontal green lines on my camcorder
Hi, I have horizontal green lines on my camcorder screen when I play the tapes back. It is a mini DV. The audio works fine. Any suggestions?
5 Suggested Answers
  • 169 Answers
SOURCE: mini dv camcorder sony
the video head of your camera is dirty or need for replacement...but first clean the head using a blank new tape,don't use a cleaning cassette cause is too rough for the head just think using a sandpaper to the head what would happen it ruin the head...just forward the whole tape then play the recorded tape...5 times as it needed...if nothing change then it time replace the video head....
Posted on Sep 02, 2007
SOURCE: Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Posted on Oct 13, 2007
  • 979 Answers
SOURCE: i get horizontal lines when
You've got a dirty head assembly at the least, or a set of defective heads...accordianman
Posted on Jul 20, 2008
SOURCE: nv-gs11gn mini dv cam recorder
I don't have specific editing software, but I recently bought windows Vista 32bit. I have a Panasonic NVGS15 video cam. When I try to connect the DV cam to the computer via a USB, it keeps telling me the drivers are not valid for this OS. Which then means when I go into movie maker, it doesn't recognise the camera as connected. The Panasonic website does not have any new drivers.Where do I get the drivers to down load the same
You are probably more of a person into the actually editing of cameras than the technical know how for this type of problem, but I thought I would give it a try.
Regards, Raju mtrajupb@rediffmail.com
Posted on Aug 12, 2008
SGNath
  • 170 Answers
SOURCE: Horizontal Streaks accross my lcd during record and playback
Are you trying to shoot from a TV or computer monitor? If so, check the frame rate--30frames per sec (fps) or 15fps. If it is on 30fps, changing to 15fps should solve the problem.
Posted on Feb 06, 2009
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
SOUNDS LIKE YOUR HEAD IS STUCK OR YOU NEED A DRY CLEANING TAPE RUN TROUGH. SOMETIMES WHEN U USE OLD TAPES THEY ARE DUSTY AND THE DIRT CLOGS THE HEAD. TRY A GOOD TAPE CLEANER
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
GREY BANNED OUTPUT
It is symptom of dirty / clogged video head.
Please use good quality mini-dv video head cleaning tape to clean head. Problem will be resolved.
Mar 16, 2009 | Canon ZR850 Mini DV Digital Camcorder
Horizontal lines in my dv tape
TRY USING ANOTHER PLAYER IT MIGHT B YOUR CAM. TRY A HEAD CLEANER
Dec 16, 2007 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR200
Hey,
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Mini dv camcorder sony
Aug 28, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Jul 16, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Jvc gr-d240
Hi: Get a head cleaner for this unit. The tape head may be dirty. Good luck. zeffy57
May 27, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Panasonic PV-GS39 Mini DV Digital Camcorder Logo
146 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
