Question about Intel D845GEBV2 Motherboard
Removal of Keyboard on a Toshiba L300. Reason to repair power plug socket All screws have been removed as with battery HD and mem. Keyboard appears to be held under the "kl" keys no screws are visible. John
I am just in the process of the same repair, and am at this step.
Look at the picture on step 7 of this guide:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
See where the red arrow is pointing? i used 2 slot screwdrivers, one on either side of this thing, and pushed up, towards the screen gently and then popped the keyboard up and over this catch.
Then, with the part of the keyboard nearest the screen held up on a bit of an angle, use a slot screwdriver to push from the bottom of the keybaord, near the ctrl and alt keys and it will pop right out.
Posted on May 13, 2009
In dell pc gx 280 she make aloud fan sound
Posted on Mar 14, 2009
Disassemble Toshiba A215-S7416 for speaker replacement
The speakers are monted beneath the top bezel that houses the keyboard.
Firstly, remove the keyboard, remove all of the screws underside of the keyboard and base. disconnect the plugs and sockets from the motherboard and remove the top chassis. There are the speakers.
Jul 29, 2014 | Toshiba Satellite Computers & Internet
My toshiba l300 can't even power.the led lights are not coming on.i have tasted the charger and it's working
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jul 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba L300 Case Repair !
Basically the input power socket need to be replaced. To get at this power socket will require the laptop to be completely dismantled to remove the motherboard to gain access to this power socket. If you find this too dificult to DIY then I suggest you get a quote from a computer repairer before you get this job done.
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
How to remove and replace the keyboard on a Toshiba notebook
Manual at Here (http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK)
it should tell you in there, you may need a positive screw driver as well
Feb 12, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba L300. The battery doesnt charge. When plugged in, no power is coming into the unit so cannot use.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 13, 2009 | Toshiba Satellite Pro L300 Notebook
Change keypadtoshiba L300 laptop
Try this....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-1.htm
The trick is to remove the screws under the battery vecause they hold the bezel into place, once that is done, pry the bezel up and out of the way then remove the screws on the top of the keyboard and lift the keyboard at a 45 degree angle and move it slightly toward the screen to unhook the tabs at the bottom. Unhook the cable socket and move the board.
Sep 25, 2009 | Toshiba Satellite Pro L300 Notebook
Howdo I remove the keyboard of my Toshiba Satellite Pro L300-19Q
Follow this instruction to remove the keyboard >>>>>
Turn off the laptop, unplug the power adapter and remove the battery.
Insert a small flathead screwdriver under the keyboard bezel and carefully lift the bezel up.
Continue removing the bezel with your fingers.
Remove two screws securing the keyboard.
Push on the plastic tab pointed with an arrow.
Carefully lift up the keyboard and place is so you can access the ribbon cable underneath the keyboard.
Unlock the connector and release the keyboard cable.
Remove the keyboard.
In order to unlock the connector you'll have to move the brown tab about 2 millimeters away from the connector base.
On this picture you see the unlocked connector.
Good luck.
Aug 03, 2009 | Toshiba Computers & Internet
Note book will not post
What's it doing that makes you think something is broken?
Dec 19, 2007 | Computers & Internet
Intel D845GEBV2 Motherboard Logo
5,187 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
