Indesit wixe127 washing machine keeps saying test and wont clear
I cant clear the test ive tried switching it off but keeps starting again on test
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
Indesit wixe127 f-08 error
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Feb 07, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Washing Machines
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Wixe127 indesit wash machine gets to 1 minute left on wash cycle and just keeps running with 1 minute on display
If all you are getting is a wash cycle and not a spinning cycle this could indicate a faulty door switch. the machine will not allow a spin cycle unless the door is locked.
Oct 10, 2009 | Washing Machines
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Indesit 1200 series wont work.
F03 indicates that the wash thermistor is open or short circuit, the thermistor is part of the heater element. you need to test the heater and thermistor, and possibly replace.
Indesit recommend that you call an engineer, but it can be done by some one who is competent enough.
Unplug before you do anything to it.
Plz leave feedback.
Thanks
Dec 10, 2008 | Indesit W 123 Front Load Washer
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Hi i have a indesit wixe127 and when i switch it on it comes up with deno and will not wash wot is wrong with it
I had the same problem with DENO, while we run the wash machine i press start button and step easier(try the start button and click buttons simultaneously until the code DOF) button until DOF code came, after everything went well. e.ladislau@yahoo.com
Jun 19, 2008 | Indesit Washing Machines
Washing Machines Logo
Top Washing Machines Experts
