Question about Epson Office Equipment & Supplies
Ink cartridge not recognized, epson t10 - Epson Office Equipment & Supplies
My Epson t10 ink cartridge cannot be recognized .. pls help me!! tnx guys:))
Posted on May 04, 2011
  • ropino Sep 13, 2011
    you can buy a gasoline and burn your printer so that you can fix after,,,,,k,
  • 161 Answers
SOURCE: Epson rx580 printer
Double check to see if the cartridges that came with your machine are really the correct ones. And if they are then make sure they are snapped in securely as they must make a solid contact to read the cartidges. Also make sure the drivers and software are properly installed onto your computer.Also make sure that the tape that is usually on the cartridges to protect them in handling and shipping are removed before installation.
Posted on Aug 06, 2007
  • 49 Answers
SOURCE: Epson DX8400 cartridge
It is most likely a faulty chip, return the cartridge to the supplier for a replacement. In my experience as many as 5% of compatible cartriges are faulty
Posted on Jul 03, 2008
CaptainHawk1
  • 345 Answers
SOURCE: epson rx595 cannot recognize ink cartridge
Just had this happen to me. Turned it off, turned it back on... nothing. In/out with the cartridge several times and when I blew on the contacts of the printer (where the little microchio on the cartridge touches) it finally worked. Did the blowing on the contacts help? Maybe, but more likely is that the it was just repeatedly trying to d oit before the machine figured it out.
Posted on Sep 26, 2009
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
Smoothly
  • 92 Answers
SOURCE: Epson Stylus NX415 does not
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
Posted on May 29, 2011
Epson 1400 not recognizing an epson ink cartridge
not necessarily faulty cartridge - had same problem went thru various cartridges some worked some didn't - in fact they weren't epson - so bought epson from office depot and that would not work, so not an issue of ink dried up - if yr printer is fairly old may be easier just to replace rather than waste time and money on trying to figure out problem
Sep 13, 2013 | Epson Stylus Office Equipment & Supplies
My black ink is cartridges is not recognized..i have a epson tx121
hi,
epson tx210 ink cartridge not recognized, epson tx121 ink not recognize, ... tx200 does not recognise the black ink cartridge, epson tx 210 product ... How serious are you to have that body you want for summer? ...
www.sulit.com.ph/index.php/...Epson+TX121/.../TX400 - Cached
May 30, 2011 | Office Equipment & Supplies
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
May 28, 2011 | Epson Stylus NX400 InkJet Printer
some printers don't recognize a refilled cartridge..... even if it was used in the printer if it was new...
but u should not have any problem printing........
the only problem u face is u can't get the remaining ink levels...
Apr 19, 2011 | Office Equipment & Supplies
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My epson printer T10 will not print. A message will appear " Ink out error".
Hi Good day!! try this method i hope it helps you
Turn on your printer and open up the cover of your printer this will bring the print head to the center after that remove the cartridges and then pull out the power cord and wait a couple of minutes "Note: don't use the off button. after that turn on the printer, now your printer will recognize that the ink cartridges is missing, after that re insert the cartridges one at the time. close the cover and see if it works.
Thank you for using FixYa
Nov 19, 2010 | Epson STYLUS R230 InkJet Photo Printer
My printer epson t10 doesnt recognized its ink cartridges,but the cartridge was genuine
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Office Equipment & Supplies
Epson t10 not print because not charge to ink
Changing Ink Cartridges? Use Genuine Epson Ink.
Are you able to change Ink? Click on link below to
download the manual etc. If you find this helpful, pls rate me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Doc
Jan 19, 2010 | Epson Stylus 880 InkJet Color Printer
Ink for epson t10 can't recognize.
Is it new original ink tank? Or used before? If "ink level" counter reach to zero, the message "Ink Out", and just said "Not Recognized". use ink tank with autorest chip.
Jun 01, 2009 | Epson Office Equipment & Supplies
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
2,484 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
