Question about Panasonic PT-52LCX65 44" HDTV
Grren Spot on TV Screen
Hi All! After a lightning storm last night we've been noticing a "green blob" on the TV screen. We have the power plugged into a surge strip, not directly into the wall. Can anyone tell me what to do? THANKS!!!
    Genius:
  • 1,139 Answers
What this problem might be is one of the guns (tubes) have been effected by magnetism. What needs to happen is the tube needs to be demagnetized with a degaussing coil. You can have theis done by a television technician. If you want to do this yourself you have to buy a degaussing coil and remove the back of your top half of your projection TV and with the set facing west take the coil holding it over all three guns and in a circular fashion rotate the coil moving away from the guns and the at the end turn the coil horizontally and remove it switching it off. This should remove the green spot.
Posted on Sep 24, 2007
  • donstv Feb 11, 2011
    This is the problem with asking tech questions online. The solution sounds good because it's technical. Problem is it impossible to "demagnetize the guns" on this TV, it's a DLP - no CRT's to demagnetize.
    I have to post a correction to my previous comment. This unit is an LCD projection not DLP. However, they are designed very similar and the same principle applies. The problem most likely needs an EEPROM update done by an electronics service center.
SOURCE:
Samsung LCD TV (Model UN65FH6001F) doesn't turn on? I have added more details in the below section.
There may have ben a power surge that caused an internal fuse to open. The power supply could have been affected as well.
May 15, 2018 | Samsung Televison & Video
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Big screen got wet in back.
Hi Check the power cord that is properly plugged in on the TV and in the wall. Check that breaker pannel that all are on. Unplug TV for half hour and try again. Hope that helps.
May 30, 2012 | Panasonic TCP42U2 4 in. TV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
Aug 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Screen froze during lightning storm. no picture now. When powering on screen lights and then dims - no picture, no sound
You might have had a power surge.Try unplugging your TV for 5 minutes and plugging it back in. If you cannot get a picture from any device such as a DVD player and cable then your TV needs serviced call a repair man. Good Luck!
Jul 14, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Loss of color after lightning storm
In tradition televisions, each color has its own gun, convergence and control circuit. One or more of these are most likely bad. Repairs on standard CRT TVs nowadays are usually cost prohibitive.
Jun 09, 2008 | Televison & Video
Panasonic PT-52LCX65 44" HDTV Logo
377 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
