Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washing for hours without graining and spinning
Washer not draining or spinning though washing for hours
  • 51 Answers
If the washer has power, and is tumbling,,, it could be 1 of 2 problems. I'm thinking either the Timer, or the Control Board.
Posted on Mar 13, 2009
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
My Kenmore washer will sometimes drain the water but the clothes are still very wet as though it did not spin. There seems to be no pattern to when it will do it. When it is spun again, it will work. ...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 28, 2011 | Kenmore 24032\24036 Top Load Washer
LG Washer WD 80490TP, At Spin Cycle not Spinning, seems to,start and then stop takes about a half hour to count down the 8 minutes of cycle, without spinning the clothes. Clothes are still wet
Pull the bottom panel off (if don't have access to the drain pump) and open the pump. I'll bet it's clogged.
Washers won't spin if they can't get all the water out...hope this helps.
Apr 02, 2011 | LG Washing Machines
How do I check lid switch without taking machine apart. The model is RAS7133KQ1. Will not drain or spin.
Unfortunaetely there is no good way to check that with out getting to the contacts and ohming them out to make sure that the switch is bad....most of the time though it is not hard to pop the top of the machine enough to check that...just need to find where the tabs are located and pop them with a screw driver...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | Roper RAS6233KQ Top Load Washer
My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
May 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My GE prodigy washer won't spin. It drains without spinning
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Whirlpool AWM029 Front Load Washer
Washer wont spin....it agitates and drains but wont spin when it gets to the spin cycle. timer still moves.
Tough to say without doing some testing. First thing to check is the coupling. It may sound like its agitating and may not at all. IF it really does agitate and won't spin, I would start diagnostically testing the timer. That isn't something your average homeowner can do though.
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
