Question about Sewing Machines
Timing off I just replaced a worm gear on my wife sewing machine stylist 534,Now the timing is off. I tried to mark the gear locations on the various shafts that I worked on. Now the needle won't pick up the bobbin thread. Is there a manual to show how to retime this machine. AB
  • 374 Answers
If the worm gear is located on the bottom of machine that has link connected to the bobbins and shuttle case.Before you engage the two gear the worm gear and the helical gear besure to adjust the position of the needle holder at the lowest dead center position and the bobbins and shuttles case was hooked up properly with the needle no thread inside also unplug the ac source before doing this.Assuming all at zero time order,you can freeely move the shuttle case with the bobbins at the center of the needle because there are no link connection when you disengage
the two gear.After setting up all at rest gradually engage the two gear and tight the allen screw no motion at all linkage when doing this otherwise changes of set up will occurs you can't get the perfect time order.If all are set, manually by hand rotate handwheel gradually if there obtruction on motion of all parts,they should be freely move on the right rotation.if OK put thread on bobbins winder set to bobbins and upper threat top spool.Set the proper tension on both lower and upper thread acquired to fabric,try too hook up the lower tension manually, If ok sew cotton fabric as trial manually only no power supply yet
until you acquired normal sewing If no problem persist.Apply power source and continue trial If problem on timing again judt repeat sequence assure the perfect alignment and setting on lower dead center.
Posted on Mar 13, 2009
How do I change the feed dog gear on a singer stylist 534
You'll need the service manual, because once the feed dogs are replaced, they need to be retimed. You can purchase and download the service manual for your machine here:
http://www.tandtrepair.com/StylistLine.html
Jan 27, 2016 | Singer Sewing Machines
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
Stylist 534 in cabnet
here is a link for part of what you need, you'll have to check with a sewing machine shop for the needles. Singer 534 Parts
Jul 14, 2014 | Singer Sewing Machines
Looking for a Singer Stylist 534 manual free
http://www.singerco.com/uploads/download/9b70a04fb6af538b67df664f5874b3fa4bf37d6c.pdf
For future reference. Just go to Singerco.com then click support and instruction manuals... enter only the number. (534)
Jul 28, 2012 | Singer Sewing Machines
How t o thread a singer stylist 534
Try this site, it has step by step instructions with pictures for threading a 534.
http://www.instructables.com/id/Threading-the-ITP-Singer-534-Stylist/
Aug 28, 2010 | Sewing Machines
Singer 2210/replaced gear/now needle bobbing cam out of sync
look here:
http://www.vacsew.com/repair/singer-600-timing.html
Apr 24, 2009 | Singer Sewing Machines
Singer stylist sewing machine 534 is not stitching
Its quite possible that the stitch length knob is set on 0 or that you have the feeddogs set on darning which drops them below the plate (if it has this feature). Otherwise the feedogs are gummed up and everything needs a good cleaning and oiling.
Hope this helps.
Rick
Feb 13, 2009 | Singer Sewing Machines
Sewing Machines Logo
357 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
