I just bought an asus X101CH-BRN006B last month and i've already encountered some problems,whenever i turn on my laptop it didn't start automatically,its always asking for the start up repair and place it on the safe mode, i've been waiting for a few minutes before it start normally. what should i do?
    Problem Solver:
  • 7 Answers
Is your laptop is having any inbuilt operating system....
if yes then first re-install the OS so that it can get back to original settings...
if no then place a OS cd and install in new partition....
Posted on Apr 24, 2013
SOURCE: unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Posted on Nov 28, 2008
  • 14 Answers
SOURCE: Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Posted on Apr 18, 2009
masteria
  • 355 Answers
SOURCE: Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
Posted on May 09, 2009
dwane4444
  • 219 Answers
SOURCE: my asus Eee pc 900hd will not start up it goes to
Try starting with "last configuration that worked"
Posted on Oct 30, 2009
SOURCE: Asus Eee PC 1005HA - Windows won't Start
i have the exact same problem. those solutions cannot help me. i dont have any hardware installed or anything plugged into it besides the power cord. also it doesnt have a cd drive so i cant put that xp cd you were talking about. what else can we do to solve this problem. i cant get past that screen to do any of these solutions. please help
Posted on Feb 14, 2010
ASUS Eee PC X101CH is not turning on
Is the battery fully charged and ok, try it with the charger connected ,if it works ok then the battery may be at fault.
Oct 16, 2014 | ASUS X101CH-EU17-BK Eee PC X101CH 10.1"...
Did asus eee pc x101ch support bluetool
Networking Networking Type Integrated Wireless LAN Data Link Protocol Bluetooth, Hi-Speed USB, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Dec 05, 2013 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
I am a senior and I purchased my Asus Eee Pc X101CH-EU17BKCB after windows updates I have had problems starting my computer. The curser just hands there, I have removed battery and restarted it - open...
I am a senior geek. congrats-so far best problem explain i have encountered here.
there r a number of possibilities.
start by trying to boot into safe mode. press F8 repeatedly after u turn on till u get menu - If it won't boot to safe mode go to last para @ end
start with the repair your computer and see if windoz can fix itself
if not do it again and select with networking option.
if it boots you can clk START and type MSCONFIG - enter
clk DIAGNOSTIC STARTUP and OK out
try rebooting normally
if it reboots, there is a driver problem.
msconfig diag mode disables everything that is not needed to boot. now u must go in and start re-enabling things till u find the one that hangs it. Start with items under SERVICES then STARTUP.
if u find one - time for another question.
if none of this works u may need to do a system RECOVERY.
W.A.R.N.I.N.G. - this deletes everything on ur system and does a clean install. If u need to get ur stuff off first - u can do that in safe mode (if u can get to it) or by removing HDD and connecting to another computer as an external USB drive..
good luck
Oct 19, 2013 | ASUS Eee PC 1000HD Notebook
Unmute sound asus u52
sounds like a bad driver download the best driver for it from their site.
Jan 02, 2013 | ASUS U52F-BBL9 Laptop
ASUS CMOS BATTERY KEEPS DYING
Yeah dump the netbook and buy a real laptop. They are nothing but problems.
May 02, 2012 | ASUS EEE PC 1015PEBRD601 Notebook
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
I purchased Shredder Model BD-S600 on 5/6/11. This was to replace another Black & Decker Shredder that I had for only a few months also. Today, when i attempted to turn shredder on to shred some...
If it's like my BD-S600 your motor is already burned out!! Same thing happened to me with this shredder after 3 months of minimal home use. I had to call them and pay $13 to send shredder back to them to have a new one sent to me, and I have already been on the phone with customer service due to problems with the new one after 5 minutes of use! Good luck to you; I know I will NEVER purchase a Black and Decker shredder again! My last shredder (a Brother) lasted 8 years with no problems and I really miss it!!
Jul 05, 2011 | Black & Decker Vacuums
ASUS U50F webcam not working for months. I have looked through tons of forums, I've tried contacting the *nonexistent* support on ASUS' website and they never even helped me. I got this notebook...
Most likely you have another chat program using the camera. Right click on the icons in the systray next to the clock and exit programs. After exiting each program, try the camera again. The last program you exit before the camera is the one causing the problem. Restart the computer and right click on that program and try and set it to not start when the Windows starts.
Jim
May 12, 2011 | ASUS U50F Notebook
Hi, i have an Asus K52J model, i purchased it in the end of August so its only a few months old. I am studying abroad in Italy for the semester and am starting to run into some problems. It started out...
In my case, the cursor jumps around when I'm typing. It could jump one line up or back to the start of the line.
Anybody with an Asus K52J ever encountered this problem?
Nov 13, 2010 | ASUS Eee 4G Notebook
Computers & Internet Logo
David Payne
David Payne
