Question about Dremel Saws
Dremmel 1571 Scroll Saw
I just bought a Dremmel 1571 Scroll Saw used. It came with blades but they do not fit. What size does this saw take?
Also where can I find a manual for the saw?  Is there a website where I can find information?
danny_murray
  • 55 Answers
SOURCE: Dremel 1672 scroll saw, owner's manual
Try this site it usually helps out
http://www.dremel.com/en-us/CustomerService/ManualsAndLiterature/Pages/default.aspx
Posted on Dec 08, 2008
rowdy45176
  • 2176 Answers
SOURCE: looking for scroll saw manuel
Go to Searspartsdirect.com and type in your model number. I checked and also found that a lot of parts for this saw are discontinued so good luck.
Posted on Dec 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Posted on Jan 17, 2009
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 15 Answers
SOURCE: truing craftsman table saw blade
Use a carpenter square to allign the blade both vertically and horizontally with your guide. This works very well.
Posted on Jan 28, 2009
Makita slide compound- Saw Blade. LS0714
It seems as though the original blade was fitted without a spacer. These usually come with any new blade. It is simply a washer (usually aluminium) that fits in the hole of the saw blade and reduces the hole diameter down to the size of the flange on your saw. This is common practice. Never try and centre a blade without the correct size hole to flange size. Very dangerous. These washes are really cheap and can be obtained from most hardware stores. Usually in an assortment of different outside and inside diameters to suit any circumstance. Hope this helps, cheers Bob.
Oct 26, 2016 | Makita Saws
I have a 12" dewalt miter saw. I put a new blade on and now at startup it makes a real loud noise.???? Took the blade off doesn't make it even bought a new blade no luck. Any answers??
Just a thought; maybe your saw requires a 300 mm blade rather than a 12 inch?
The popular view is the two sizes are interchangeable but there is a small difference in diameter with the Imperial blade being about a quarter inch bigger than the metric.
I had a similar problem with an eight inch saw. When I fitted an eight inch blade it seemed to be ok but when switched on it made a loud noise, similar to yours I guess.
I was unwilling to buy another blade so I modified the saw to give the blade housing a little more clearance so I could use the eight inch.
Jan 17, 2016 | Saws
What size blade do I use on a performance tough 18 in scroll saw?
Scroll saw blades I've dealt with are all the same size--just the tooth count per inch--need more info.
Aug 21, 2015 | Saws
Are there any other rand of saw blades that fit a Delta 40-130 scroll saw? I understand delta blades are obsolete and can't even find the part number For reference. It is a pin type
i see scroll saw blades all the time at menard's and home depot.but if you search amazon.com they have lots of items and just may have them
Mar 21, 2015 | Delta Saws
How can i fit a replacement blade to scorpion saw model KS 8906T
If you have a old blade for the saw you can modify other new blades to fit using a grinder to shave them down to the same size.
Jul 25, 2014 | Black & Decker Saws
21 cm saw blade
21 cm is 8-1/4 inches. You could use an 8 inch blade or 7-1/4. But the diameter of the blade is not the critical thing. You must have a correctly fitting hole in the blade to mount on the saw shaft. Standard English size of the hole is 5/8 inch. Just take your saw with you to the store and try a blade on it. If the hole is a nice fit, your are good! (You posted this under circular saws, so I assume your saw is portable.)
Feb 26, 2013 | Saws
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Saws Logo
366 people viewed this question
Top Dremel Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Raymond Richards
Raymond Richards
Are you a Dremel Saw Expert? Answer questions, earn points and help others
