Question about Amana HKR-15C 15kW Electric Heat Kit 51,150 BTU Circuit Breaker
Hkr-15cb skemattic... wire diagram
My webcam does not work on my asus screen
install proper drivers,.. If its windows 7 and you are using drivers of the chicony cam, the image is upside down, you can alter its *.inf file there are 2 lines wich need other settings. make 0 into 1 and youre ready to go!
The lines in snp2uvc.inf file are:
You'll see entries like this...
"HKR,DefaultSettings,Flip,0x00010001,0 - and - HKR,Settings,Flip,0x00010001,0".
Change the last digit (zero) to a "1" to all instances
this enables the cam to flip its image 180 degrees so its back to normal!
Yours sincerely,
Dennis
Apr 05, 2013 | Computers & Internet
Does not heat
Sounds like either the heat sequencer is not working or maybe you have the thermostat set to "B" when it needs to be in "O" or vise-versa. The wire to check should be orange if wired up in a common fashion. Also, you may have a system that requires a jumper wire from "W1" to "W2". If your blower is running I would check these 3 things before anything else. I hope this helps, I will be on tomorrow also and I'll keep an eye on this with you. We can get this one banged out.
Feb 12, 2013 | HD SUPPLY DUROGUARD 10KW HKR SERIES ELECT...
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
Inverted image webcam, laptop k50c, I can do
Here's a solution, and its source:
I have the same problem with an N50v.
I resolved it by editing the snp2uvc.inf file.
Open it with notepad and search for the word "flip".
Change the last digit (zero) to a "1" to all instances.
Save the file and re-install your drivers manually from Device Manager.
Choose the driver to install, do not let Windows search for you.
Reboot and your video will be in the correct orientation.
http://forum.notebookreview.com/threads/g50v-upside-down-webcam.299525/page-3#post4188410
Jan 03, 2018 | Computers & Internet
Need to how the power source will be hooked up, and how, it will wire into a 13 SEER Goodman Packaged Unit, with HKR-15 strips. wire size?= 15 Ft. run: panel to unit
Minim 20 amp circuit ... is this 110 or 220? You need to know.
20 amp circuit needs to have #12 wire. If 110 Volts, you need a black, white and green #12. If 220 Volts you need a black, a red, and a green. If you have anything IN the unit that needs 110 (probably not), you need black, Red, White and Green (bare) #12 wire. Definitely needs to be on a dedicated circuit. If your unit has a resistance heater (electric) you will need a 30 amp circuit (probably 220) which needs #10 wire minimum. 220 volt breakers are double. You will need two spaces in your panel box. Would not hurt to put in heavier wire (#8) protected by a 30 amp breaker ... $ is the governing factor.
Having said all of that --- you should be reminded that I dont even know what country you are in nor your prevailing voltage nor what your national or local codes require. My comments based on installing several Goodman products over several years on the Eastern Seaboard.
Aug 26, 2011 | Heating & Cooling
The image on my asus k50i webcam is upside down and dont know how to fix it went to life frame settings but didn't have the option to flip need help
You must install the Generic Microsoft versiom USB Camera from this K52N Camera_Azurewave_VS011_WIN7_64_z5854000205.zip
Or other notebook but azuware VS011.
If after intalling driver, your camera is mirrored and/or inverted you may simply edit the snp2uvc.inf with notepad and find:
Flip and Mirror and change the value from 0 to 1 or from 1 to 0 so to invert or no. 1 equals YES
e.g.:
HKR,DefaultSettings,Flip,0x00010001,1
to
You have to apply the same value to all occurrences though.
Enjoy and happy webcamming...
May 19, 2010 | Computers & Internet
Driver for my creative speakers with sub woofers was lost and computer has to undergo reformatting. Sounds from creative is not working after reformat. Please emial me on what is the best thing to retrieve...
You can go to the reative website and give them a description of your device and usually they will have the drivers for you to download, usually free,,,,Hope this works...Darren
Oct 11, 2009 | MPC Computers Millennia 920i Creative...
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Monitor dark for 20 minutes before turning on
My VL1919 has been having this issue off and on for a month or so now. It happened three times in one day today, so I decided to do something about it. I opened up the monitor and poked around a bit.
I found three electrolytic capacitors on the backlight inverter board were bulging, two of which had just started to leak: 71706a0.jpg The capacitors were placed directly above and next to a large, flat metal heat sink. I say above with respect to the flow of air due to convection, and next to because the heat sink also wraps around, enclosing the group of capacitors on one side. The heat sink sits flush with the circuit board, turning the board into a front enclosing face. When reassembled, the metal housing sits a fraction of an inch above the sink, forming a back face. This assembly is at the top edge of the circuit board, so the housing then takes a 90° bend to form a top face. These capacitors seem to get almost no air flow... Together with the heat coming off the sink, it appears the engineers have created their own little capacitor oven. Capacitors immediately adjacent to the affected components, but without blocked air flow looked completely normal. Looking at the traces on the circuit board and location of other components, the capacitors could have easily been moved out of the hot spot. This is either an act of gross negligence, or an intentionally created post-warranty failure point, designed to avoid market saturation. But that might be too pessimistic... "Never attribute to malice what can be adequately explained by incompetence." Anyway, I scavenged a few capacitors off an old computer power supply to replace the damaged parts (one 470uF 25V two 1000uF 10V capacitor, both rated to 105°C). To avoid a repeat performance, I soldered some short extension wires to the replacement caps and moved them out to an open area of the board, being careful to give the high voltage components plenty of breathing room. After reassembly, the monitor powered right up and came online. I guess the real question is how long it will stay this way.
Apr 05, 2008 | Princeton Digital VL1916 19" LCD Monitor
Amana HKR-15C 15kW Electric Heat Kit 51,150 BTU Circuit Breaker Logo
197 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
