Question about Travelpro Atlantic Ultra Lite 22 Upright Carry-On Luggage - Blue
Handle stuck in closed position - Travelpro Atlantic Ultra Lite 22 Upright Carry-On Luggage - Blue
My 1955 Chevy pickup drivers door is stuck in the half closed position. Won't open or close with inside or outside handles.
Have you tried to remove the interior door trim and see what is causing your handle to only move partially ?
Nov 27, 2016 | Cars & Trucks
Why would automatic sliding door not pop out unless you pull handle?
Sometimes the lock on the handle from the interior gets stuck half way in/ out. Check its position. Mine does this periodically and then won't close, keeps opening. Also verify child safety close switch is in correct position.
May 01, 2014 | 2006 Toyota Sienna
Drivers side sliding door won't close
check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
Jan 01, 2014 | 2004 Nissan Quest
Unable to close door
I have 2 different door problems with my 99 Park Ave: one door opens more than it should and often can't get it to move to close it and the other door opens but when trying to close it, the door will not latch closed. I'm not exactly sure what you mean by door wouldn't close, but with your mention of the metal parts, I'm gonna take a guess that it doesn't latch closed (kind of bounces back open too). For that problem I do 2 things to avoid actually fixing the problem. First, I check that the door handles are in the closed door position (my outside handle stays stuck out in the pulled position); I push them both in. If that doesn't work, I push down on the latch mechanism in the edge of the door to find that it was stuck in the open position. Once I do those 2 things, my door closes perfectly.
I hope this helped!
Jan 30, 2012 | 1999 Buick Park Avenue
Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
Feb 17, 2011 | 1998 GMC Jimmy
The locking mechanism on the rear passenger door isnt working.The door will close but the metal catch will not lock.How do i repair?
I have seen some times the latch assemblys get rusty or dirty and the inside or outside door handles are pulled and the latch assembly siezes in the open position not allowing the door to latch closed..but this may not be the case .. check to see also if the child lock switch position is not stuck in the halfway position, also check if the latch has not flipped to the close position before the door was closed thus jamming the striker latch..this can be fixed by pulling the catch out while opening the door handle..hope this helps good luck...
Nov 05, 2009 | 1995 Pontiac Sunfire
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Recessed handle is stuck in closed position
I would likely try WD-40 and gentle maneuvering.
How long has it been since it work and you've tried it again?
Mar 21, 2009 | Atlantic Luggage Atlantic, Inc. Wire...
I HAVE A 1996 MERCURY VILLAGER AND YESTERDAY THE BACK HATCH WOULD'T OPEN. IT'S LIKE IT 'S CAUGHT ON SOMETHING
The handle may be stuck in the open position due to rust. Try to push back the handle and play (open/close/open) with the lock control. The same thing will eventually happen to the sliding door, and the culprit is the inside handle, stuck in the open position, preventing the door to close completely. Good luck.
Jun 29, 2008 | 1996 Mercury Villager
Travelpro Atlantic Ultra Lite 22 Upright Carry-On Luggage - Blue Logo
81 people viewed this question
Top Travelpro Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Travelpro Luggage and Travel Expert? Answer questions, earn points and help others
