Question about HP LaserJet 3600n Printer
Can't get right side panel off on 3600n printer
I need to get in and do a repair that HP tech support sent me instructions on and the part. Unfortunately, I can't get the door panel off. (this is the first step).
    Genius:
  • 2,120 Answers
You have to remove the formatter metal cage first by releasing black tabs then you can reach the snap tabs, be careful with on/off switch lever, Are you replacing cartridge locks?
Posted on Mar 13, 2009
Hey, I am really at my last wits with this printer.I have a color LJ 3600N. I received the 10.92.00 error. So i replaced the left and right lever lock. After the repair it worked for like half hour.
You replaced the lever locks but did you replace the actual cartridge locks. Chances are either the left or right cartridge lock for the black toner cartridge has broken. Remove the toner cartridge and then lift the transfer belt to the closed position. You should see a lever drop on both left and right side. If the are missing or broken you will need to replace them.
Oct 23, 2016 | HP LaserJet 3600n Printer
How to remove side panel hp 3600
To remove the side cover: Open the fuser cover and remove the fuser. There are four screws that hold the top cover on, remove those and lift the top off, watching for the connector wire on the right side. Remove the formatter. On the bottom of each side panel, where the lift handle is, there will be 1 screw, remove the one for the side you want to remove. If you want to remove the left panel there is also a screw on the lower back of that panel. The right panel only has the one screw. If you go to feedroller.com you should be able to download the service manual that will give you detailed instructions and pictures.
Aug 15, 2014 | HP LaserJet 3600n Printer
Cartrage not engaged
Try to follow the instructions in a user's manual:
http://www.retrevo.com/support/HP-3600n-Printers-manual/id/313ag619/t/2/
www.hp.com/support/cij3600
Jan 24, 2013 | HP LaserJet 3600n Printer
COLD RESET HP 3600n
Click Here for instructions on cold resetting a 3000, 3600 or an 3800 hp laserjet printer... Be sure to leave it marked as FixYa!! if this info helped...
Nov 05, 2010 | HP LaserJet 3600n Printer
I have a networked HP 3600n printer.\r\n when printing in grey scale it prints in reverse, so the black is the back ground and the writing is white. Can anyone please advise? The OS is XP and the server...
The "Mirror Image " printing option is enabled.
Click on START - Control Panel - Printers and Faxes. You will find list of Printers Installed
select the HP 3600n Printer icon and right click on it. Select Printing Preferences. Under Advanced Features you will find "Mirror Image" - Choose OFF and Click ok and Save the settings and try printing.
Jun 17, 2010 | HP LaserJet 3600n Printer
I have a HP 3600n. Starting at the center of the page the print fades way to no print at all on the right side of the page.
Usually that happens when the ink level is too low.. whether it shown some alert about low ink level?
Apr 09, 2010 | HP LaserJet 3600n Printer
Hp 3600n getting error msg that cartridges not engaged
The problem is the locking arms on the right side of the machine are probably broken. HP has a tech bulletin out on this issue and they have a kit with updated parts to repair it. It is a very common problem.
Mar 24, 2009 | HP LaserJet 3600n Printer
Hp Color LJ 3600 continue. Calibrating
Had a similar problem with a customer's printer. HP tech support had me change out the environmental sensor and the boards, this did not fix problem. In the end we had to get a replacement printer (thankfully the unit was under warranty)
Jan 10, 2009 | HP LaserJet 3600n Printer
HP 3600n Cartridge Memory Tag
Check the latch on the right side of the black cartridge. They have a problem with them breaking. There is a new style available.
Oct 18, 2008 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
152 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
