Question about Dishwashers
GE Profile dishwasher not drawing water from water line
For some reason the dishwasher doesn't pull water from the water line. It does sometimes but never for a full cycle. Could there be air in the line?
The dishwasher runs if I keep pouring pitchers of water into it but that still doesn't get dishes clean the way they are supposed to be...
No problems draining, just filling up
  • jboooor Mar 13, 2009
    Hey, Joe
    Unfortunately that doesn't do it. There is no screw on the front "float" device on that area of the dishwasher.
    There is a threaded plastic piece that I removed but it does not have anything on it. After I unscrewed it there was only the metal bottom of the dishwasher and the other plastic threaded part that attached to the rest of the fixture...
  • 10,865 Answers
If you look inside the dishwasher paying special atention to the left front corner. Remove the lower dishrack and then you will see a dome shaped piece of plastic attached by one screw. Remove this screw and check and see if the float is gunked up. Sometime you have to remove the lower access panel to remove a little pal nut off the bottom of the float assembly to actually remove it to clean. Clean it real good and reinstall. This should solve your problem.
please mark my answer as a fixya! thanks.
Posted on Mar 12, 2009
  • Dave Ang Jun 18, 2012
    This worked great! I was ready to buy a new dishwasher! Thanks for the save.
Hey justaskjoe, you just saved me $100 or more for a trip by a GE technician. Thanks a bunch. GE website has a video that says tap that float with a wooden spatula. I guess GE (or any manufacturer for that matter!) folks would never tell you to open their appliance. So, all the more reason for me that your simple solution was a great saver!
Posted on Feb 05, 2010
My dishwasher GE profile quiet power II MV832134B GSD 4030Z04WW will not drain.
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Jun 27, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I NEED TO REPLACE PUMP ASSEMBLY IN MY ge PROFILE DISHWASHER. Can I do this by myself
yes you can take the model # down and get the right pump.. take the water line off and pull it out and put it on the side very easy good luck
Dec 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Water is sitting in bottom of dishwasher after cycle is completed - fair amount of it
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | GE Profile PDW8000G Built-in Dishwasher
GE Profile 7880 will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile doesn"t drain completly, leaving about 2" of water.
Sounds like a water level sensor is on the fritz. The drain valve is probably opening if the level drops at all.
Jul 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE Dishwasher Problems
Disconnect the drainline and hook up a shop vac set up for wet and draw the drain line clear. Sure it isn't the pump?
Jun 01, 2009 | GE Profile PDW8400J Built-in Dishwasher
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Dishwasher
It could be a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle,it pushes the water out of the dishwasher. The motor and pump are located beneath the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around freely. In case it doesn't spin freely, look if it doesn't blocked or stuck from any other reason. Good luck!
Sep 10, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
849 people viewed this question
Top Dishwashers Experts
