Question about Terk XMD1000 Satellite Radio Receiver
Need power pinout for XMD1000 receiver
I got a refurb unit that didn't include a manual (which I cannot find online for some reason) nor the power cable. I desperately need to know the type of connector and the pin layout.
I need the Airbag Wiring Diagram for a 1995 Honda Accord
helm has a great factory service manual selection, also you can probably get lucky and find one in a google search or maybe even on here. search "1995 accord service manual" i remember seeing them free for download or pdf view online. I know i seen alot more for earlier and later accords than my '99 when i was searching yesterday. good luck
Apr 19, 2013 | Honda Accord Cars & Trucks
Lg optimus chic e720 does not turn on
Hello all,
Please Can you support me ? I have an LG optimus Chic LG E720 that didn't boot and didn't enter in emergency mode due to bad software update. Power cut during software update.
So I need to know JTAG Pinout or whish flashing Box can I use to repair it ?
thx
May 03, 2012 | Cell Phones
Why does my xm radio always have to be refreshed after my vehicle has been turned off. The poer to the radio is not lost because the clock is always running. I have to refresh the radio everytime I want to...
You need to have one wire on an always 'hot' power feed. Be careful, as some GM products have a timer that shuts off the power after a 10 minute timer, so that could be your issue. Are you talking about a factory installed XM, or one like the photo above?
Jun 14, 2010 | Terk XMD1000 Satellite Radio Receiver
Terk XMD 1000 need power coed
You can make one if you have the 4 pin white nylon connector. You only need 3 pins, one to 12volts for memory, one for 12volts accessory radio power, and one for GROUND. Let me know if you have the 4 pine white nylon connector, then I'll get you more info, okay?
Jun 17, 2009 | Terk XMD1000 Satellite Radio Receiver
Schematics forpower supply
Go to this site: http://pinouts.ru/pin_Power.shtml.
It should have the pinout info you need. If you're intending to fix the unit, you can get a replacement (with more power) at this site for less than $20, including shipping: http://www.geeks.com/.
Apr 04, 2008 | Sparkle Power (FSP250-60SPV) (FSP25060SPV)...
Service Call 3-31H is displayed on the screen
The technical manual is stating that the problem is with the left lock lever make sure that the door is shut correctly power down then back on again. If the problem comes back I think it maybe the laser unit then and it will need replacing.
Thanks J
Oct 17, 2007 | Ricoh FAX3800L Plain Paper Laser
XM RADIO PROGRAMMING
For the Ilo CA3000v, all you need is an XM direct tuner box, Model XMD1000, the cable that came with the Ilo radio, and an RCA cable to connect the two. The RCA jacks and the 8-pin DIN jack on the back of the ILO CA3000v are exclusively used for XM signal translation. You will, of course, need a subscription to XM Satellite radio, but the items listed above cover the extent of the hardware you'll require. The XMD1000 comes with the antenna as well, so no need to worry about that, and all XM features are controlled from the head unit itself
Dec 11, 2006 | iLO CA3000V CD Player
Terk XMD1000 Satellite Radio Receiver Logo
161 people viewed this question
Top Terk Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Terk Audio Player and Recorder Expert? Answer questions, earn points and help others
