Question about JVC GZ-MC500 Memory Card Camcorder
Turn on monitor working (menu) but won't see picture on screen.
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Forgetting that the computer was on, I went to turn it on and shut it off while in sleep mode. The screen won't work.
A monitor does not normally save any states such as sleep. If unplugging the monitor from the power source for ten to twenty minutes and re-plugging it in does not fix the problem check and see if the monitor's menu comes up.
Even in sleep mode, the menu for the monitor should show. If it does, try resetting the monitor to factory default settings. If the menu does not show up, then there is an issue with the monitor.
Jul 04, 2012 | Dell Computers & Internet
Menu box won't come off screen
Unplug the monitor power cable and plug it in back after 5 seconds. This should remove the "menu box". But I suggest you to call technician to fix the hardware problem with your monitor buttons.
Dec 18, 2011 | Proview PL 766s 17 in. Flat Panel LCD...
Menu box on screen won't come off
If the buttons are micro-switch type buttons (like you would have on a car's alarm remote) and they don't have the proper feel, then the monitor is probably ready for the recycle bin. Doing a little looking around it appears that the monitor you have is prone to failure. I think you should look into a replacement. Samsung makes a great monitor these days. I would steer clear of anything made by HP. Here is a link to someone else's woes with that particular monitor. Good luck!
http://h30499.www3.hp.com/t5/Home-PCs-Pavilion-Presario/f1703-Monitor-Menu-stays-on-screen/td-p/557824
Why won't new screen come on when powered uo?
I can only guess from your question, but I think that your previous monitor had settings that the new one does not support.
  • Try to connect older one to the computer and lower the resolution and Frequency rate of the monitor from its properties menu like on the picture.
  • After that connect the new monitor. This should do the trick if the problem is in the unsupported settings.
If you can't see the initial bootup screen, then probably the problem is in your cable or video card. This usually can happen when using DVI output.
Nov 26, 2011 | eMachines Computers & Internet
I have HP w2338h moniter .Its screen show menue screen again and again .
Hi hsaiyed,
appear. You can do different function you want for your monitor to do such as turning the menu off. Observe if the button is working properly, if it is stuck the "menu" on screen won't go away.The buttons are either on the right hand side facing you or under the panel.Buttons go bad due to improper use. If it is bad you have to replace the control panel.
Hope this helps.
Thank you for using FixYa.
Jul 21, 2011 | HP Computers & Internet
The menu screen is on and we can not take pictures, we can not get out of that setting
Hi, If it won't let you quit out of the menu screen I'd suggest turning the camera off then on, if that doesn't work take the battery out for a couple of minute and that should do the trick.
May 12, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
JVC GZ-MC500 Memory Card Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
