Question about Welding Tools
Engine won't run smooth for longer than 5-7 mintues
Kohler 12 hp new on lincoln gen/welder (27 hrs on unit) starts good runs very smooth then 5minutes of running drop down in rpm to almost nothing then will pick and good for another 5 mintues then does the same thing. Does this under load or no load high idle or auto no differance.
  • jhamner_1 Apr 02, 2009
    Choke was not on. I was running under load as a gen. (20-25 amp) when this started.
  • gerardmccabe May 11, 2010
    is your choke still on if not check and see if it welds alright if it does then its a petrol and noise reduction on
    President:
  • 1,714 Answers
The throttle control board is not working corrctly
Posted on Jul 11, 2009
Changed filter, oil, full of gas checked gas flow everything is good , when I start m lawn mower it runs , when I engage my pto and start mowing for about 5 minutes it just quits
if this is got the 27 hp kohler engine, I know exactly whats wrong with it , due to grass and engine oil building up in a short time under cylinder heads , it actually makes a tight ball of grass and stuff there !! this holds the engine heat and ruins the ign module that's just above it there , I put two on in one season ( tractor runs 6-10 hrs day 6 days a week ) I finally gave up I bought a Kawasaki 27 hp twin and installed it , now its run for two seasons and no problems
engaging the pto has nothing to do with it , it would cut off if you just drove it around for 15 minutes
Sep 15, 2015 | Toro 52" 27hp Z Master Zero Turn Lawn...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
Jan 25, 2013 | Lincoln Ranger 8 8000 Watt Kohler Gas...
My 3.5 kw kohler marine gen starts and shuts right off throwing code uu (under voltage) last season it did this and sometimes showed loc (loss of coolant) but never appeared low or showed sign of coolant...
Check that when you run it, it is not in fact making correct voltage (within about 10% is good), also make sure the engine is coming up to full speed, 3600 or 1800. You could check this with a multimeter that measure hertz. On the main output leads when the genset is running make sure it is getting close to 60 hz. or if you are in an area that uses 50 hz. check for that respectively. There are a couple things that would affect this, one would be your SCR module. There is a test procedure for this which you could find here. http://www.scribd.com/doc/50171916/tp6196-1 . I don't work on marine units, mostly standby so these manuals are for residential. Check your fuses, could even go as far as checking the wiring in the back and wiring and condition of the brushes and sliprings. These actually build field voltage to make 240 or 120 volts whatever your unit is configured to make. The brushes need to sit flat on the slip rings and on a unit with 10 hrs. the sliprings I can't imagine would be very dirty but check that as well. If you have an ADC2100 controller use this manual to go into the controller to verify that it is set for the correct voltage that the machine is built to make. The only other fairly simple thing to check that I've had issues with is if Kohler mounted a fuse block on the side of the cabinet mounted to the genset with no vibration isolation. Check these fuses while attempting to run the unit and make sure you getting steady voltage out of them as sometimes they will vibrate causing pulsed voltage to come out of them and can give you an intermittent UU, UF, or OC fault (undervoltage, underfrequency, overcrank).
Jul 13, 2011 | Kohler 12 kW Emergency Power System -...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
I have an 18kw kohler generator. the unit is aprox 10 years old...has about 150 hrs on it. over the weekend, when the power was out, it was running just fine when all of a sudden the ford engine...
change the temp sensor and re test the gen set these have a bord that senses if theirs a issue with the engine and will cut the bower to the get head so theirs no load on some mod's then when the temp reaches a higher point they shut down. re-post is this does not fix the issue i will review the books on the unit.
hope this helps
Aug 09, 2010 | Kohler 18RESL 18 kW Emergency Power...
I have a kohler engine on my ranger 8 welder and i can get it to run for a few seconds then it quits or if i keep putting gas in the carb it will stay running .
sounds like filter/line blockage....check all lines and clear them of any contamination...maybe some dirty fuel or water in fuel has been added into the storage tank.
Jul 23, 2010 | Lincoln Electric Ranger 305D K1727-2...
Welding Tools Logo
131 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
