Question about Home
No instructions for pegausu bamboo shower and bath faucet
Bought this about 200 miles from home at home depot there isn't one close to us . It had no intructions in box . Help
  • Bill Johnson May 11, 2010
    what can i help you with?
  • Bati99
    Bati99 May 11, 2010
    Can you please give more information and specifics? Pegasus makes a huge range of products.
  • 8,197 Answers
May I get the make and model # to help you more
Posted on Apr 05, 2010
Tip
How to repair a washer-type bath & shower faucet
  • To take apart a bath/shower faucet for repair, first turn off the water. Then take the faucet apart by removing its handle, escutcheon and packing nut. The packing nut may be buried deeply in the wall, requiring a socket wrench for removal.
  • Your bath and shower faucets may have a renewable seat that can be smoothed with a seat-dressing tool or removed and replaced using a seat wrench. For replacing and repacking the washer, follow the same instructions provided for a washer-type faucet. Some faucets may need a complete replacement of the combination stem/seat unit.
on Jan 16, 2010 | Plumbing
How to pull a stuck moen 1224 cartrige ?
The make a cartridge puller you screw into the stem.... You can however use a vice grip and some leverage you must be able to grab the stem i believe you can put the screw that holds the handle into the stem then take a vice grip grab the screw then use a piece of wood to pry against and get it out the stem puller saves you a real headache pick one up at lowes or home depot
Sep 03, 2014 | American Standard Hampton Two-Handle...
The shower does not get hot so i took pressure balance unit apart and cleaned also took hot limit stop off .still not hot rest of sinks in house are hot and furnace right under shower,what do you think it...
When shower faucet apart make sure hot is getting 2 & coming out faucet ***. did you turn off stop integral w/ faucet or outgoing shut off valve on water heater.. May have rust or lime in small orifice leading to faucet ***. does your balancer/ piston move freely..good luck..
Mar 24, 2011 | American Standard Bath Faucet Ceramix...
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Shower/tub faucet does not provide cold water, only to warm and hot.
The faucet has a cartridge that is dirty or bad. Turn off water to the house and remove the cartridge. Take it to Lowes or Home Depot and get another replacement. follow the instructions in the package to the tee.
The old cartridge easily pulls out after you pull out on a clip on the top of the internal assembly. Just take the handle off, slip out the chrome sleeve and remove the clip. The cartridge will pull out with minimal force.
Then head to the store!
Oct 13, 2010 | Moen & One Handle Tub & Shower Faucet
Old faucet doesn't have a replaceable seat..new does
you bought the wrong one you need to get the right one the are the same and not diffrent.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Home Logo
95 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
