Question about Ricoh Office Equipment & Supplies
Ricoh ft 4615
What over mean in copier RICOH FT4615
NALDZ
  • 38 Answers
SOURCE: User manual for Ricoh FT 4427
I WILL GIVE YOU A MANUAL RICOH FT 4427 BUT YOU NEED TO PAY 100 US DOLLAR. EMAIL panlaqui08@yahoo.com.ph
Posted on May 07, 2008
fotobean
  • 103 Answers
SOURCE: On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
SOURCE: how to reset passcode, copier given to the church. Ricoh Ft 5535
This will require a tech familiar with this machine to reset. The user code option is enabled by both a setting within service mode, and a jumper being disconnected on the motherboard of the copier. This jumper will need to be reconnected and the settings changed within service mode.
Posted on May 26, 2009
goodgold
  • 389 Answers
SOURCE: I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Posted on Sep 13, 2009
  • 541 Answers
SOURCE: Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Posted on Jan 10, 2010
Hi. I have a ricoh ft 4615. Heating is ok, gears moves as normal, each n every function is working but the print page is blank and displays U6. What might be the problem?
Try this:
Turn off the auto density
Go to manual density and adjust to the middle 50%
Try to run again and check your results
If none - you have to clean all the optics
Try again - if you don't get results there is a possible problem with the lamp/scanner system which usually requires someone making adjustments to one of the control boards.
Which brings you to contacting Ricoh for support - they are usually pretty good helping over the phone.
Ricoh's support and download link is below, if this doesn't work scroll to the bottom and click on contact us.
Support and Downloads
Best Wishes,
Joe
Aug 25, 2016 | Ricoh Office Equipment & Supplies
RICOH FT 4615,ANALOG ERROR 54. wHAT DOES IT MEAN?
first check if there are any soot of toner inside the fuser,you can either replace the whole fuser assembly or fuser thermofuse/thermister to solve your problem
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Ricoh ft4615 e11
Damaged Exposition lamp, thermofuse open, lamp contacts dirty or oxidized , lamp power supply faulty or loosen /broken cables. This are the most probable causes.
Add a Video
Apr 28, 2014 | Office Equipment & Supplies
Ricoh ft4615 e 11
e 11 -exposure lamp error 1.Possible causes:triac short circuit,exposure lamp open,thermofuse open.To reset turn turn main switch OFF and ON.
Dec 28, 2013 | Ricoh Office Equipment & Supplies
My ricoh ft4615 have an error E40. what does it mean??
E40 means that you have an open thermistor, which needs to be replaced.
Mar 21, 2011 | Ricoh Aficio 2015 Copier
COPIER RICOH FT 4418 ERROR CODE E 553 what it means please.it appears on switching on. Iam clueless so I havent touched it.
this proplem happened when main motor in machine have big load in his mechanism due to slow movement in units so try check on belts in behind machine
Jan 20, 2011 | Ricoh Office Equipment & Supplies
Bleda kopja i posle zamene bubnja i developera.na ricohu FT 4615
Please in the english or in the francaise or ungarische for help .
Nov 12, 2009 | Ricoh Office Equipment & Supplies
Ft 4415 ricoh flahing the magnigication indicator display
That means the machine is due for preventive maintenence, or PM. There is an internal counter that keeps track of the number of copies made. At a preset count, this indicator flashes. Kind of like "it's time for an oil change"
Aug 24, 2009 | Ricoh Office Equipment & Supplies
I need a ricoh ft 4220 manual. Can you email to vaughan@vkeal.orangehome.co.uk
Yes, I have Ricoh FT Ops manual and service manuals wich do you need?
Jun 05, 2009 | Ricoh FT3713 Copier
Mar 20, 2008 | Office Equipment & Supplies
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
