Question about Maytag Dryers
Maytag stackable gas drier does not start turning reliably
The dryer acts like the motor is overloaded then overheats and occasionally will not start. The empty drum turns - by hand - but seems way too hard. The rollers in the rear seem to turn ok when the drum is lifted to free them. Does the front of the drum have a friction support? If so, how can it be checked and if necessary replaced or repaired?
Thanks, Erv
  • 3 Answers
GE dryers tpically use polyethelene slide strips located at 4 o'clock and 8 o'clock. There is a special grease specified by GE to lower friction and increase the life of the slides, with the key feature being that the lube does not damage the poly slide strips. The strips are available in a kit or premounted on the steel bracket. If you are comfortable with drilling out the rivets that hold the strips in place, just get the strip set - about $ 18 a year ago. The premounted strips will be less aggravating with only a slightly shorter install time.
You'll find the strips mounted inside the front cover just below the door opening.
Posted on Mar 13, 2009
It looks like Maytag LSE7806GGE dryer overheat thermal switch shutdown the motor. The motor is new. The vent looks good, plenty of airflow as well. What can be cause of this?
Lots of things.
Here are a few.
If the belt drives the drum, and the drum is not turning freely, perhaps it is loading the motor with too much resistance and the motor is overheating and shutting off.
If there is a bad ground wire anywhere in the system., perhaps the motor is not being grounded properly, and is having an electrical "melt down".
If the dryer is overheating because of lint accumulation inside the pipes of the dryer, perhaps the extra heat is shutting the motor down.
If the dryer is overloaded with clothes or whatever, perhaps the pull is too much for the motor and it overheats.
God bless your efforts.
Oct 31, 2016 | Maytag Dryers
Maytag Neptune stackable washer/dryer dryer not heating up?
check house braker, element, thermal fuse, thermostats, wires and connections including to the motor as the motor switch acts on the element. if all is good your electronic board should be the problem.. a local part dealer will usually help you in testing your parts if you dont have a multimeter..
Jan 28, 2015 | Maytag Washing Machines
Why does the gas dryer sound like there is blower running, occassionally, when it is off.
In order to clear all gas fumes out of the unit after the burner was on.
It also runs before the drier flame starts.
Jun 12, 2014 | Maytag Washing Machines
Maytag stackable dryer will not run. When the start button was pressed, there was a sound of the motor trying to turn, but there was not turning. When pressed repeatedly, there is a burnt smell
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2010 | Maytag Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Changed thermal fuse and cleaned out drier. it ran good for about 20 minutes and then shut down again. what could be the problem
changing the thermal fuse was a good idea but if the dryer runs for 20 min. then shuts off that is generally the motor going into thermal overload....thus meaning you would need a new motor.
Oct 02, 2009 | Maytag PYE2300AY Electric Dryer
Intermittent operation
This sounds very simple. If the dryer vent hose is partially blocked, the unit will overheat and shut down on thermal lockout. This is an auto reset limit switch. After the unit cools down, it will reset on it's own. This will be very intermittent. Clean the vent real good and be sure to clean the vent inside the unit as well. Then retry.
Apr 09, 2009 | Maytag Dryers
Matag stackable My Drier Squeals loud on start up
could be motor put oil on back baring aka rollers
Jan 29, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag gas dryer problem-
it is a heat coil problem
Oct 20, 2008 | Dryers
Maytag dryer will not start completely.
replace motor it would hold a load and is kicking out on over load switch
Dec 08, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
