Question about Genius Wayne Submersible Sump Pump With Switch
Genius float switch
My pump wont shut off
2 Suggested Answers
  • 323 Answers
SOURCE: Are the genius switches any better than the float switches?
If you are placing a sump pump in a smaller, more confined area then yes. They both have their downfalls, and either can fail without notice. The ones that slide up and down the rod can get stuck or jammed, sometimes even due to build up on the rod. I tend to favor the genius switches, but either needs to be checked out periodically.
Posted on Nov 03, 2009
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
The is no water in the hole where the sump pump so why is it still running?
The float that turns the pump on and off is bad or stuck...
Pull the pump out and check the float... if it shuts off the find out what was holding it up...if it still runs the float is bad and will need to be replaced...
heatman101
Mar 23, 2011 | Genius Switch Submersible Sump Pump...
My sump pump wont kick off. There is no water in the sump and the float is fine, but the motor won't shut off. I unplugged the pump as to not burn up the motor, and thinking it may reset itself, but when...
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
Jan 09, 2011 | Flotec Automatic Sump Pump Float Switch
I have a flotec model 1m03w fp053200a-o8 1.5 hp sump pump. It run all the time now, the only way it shuts off is if its unplugged. Do I need to replace it, or can it be repaired? Thanks for your time
If you have the pump pictured, there is a float switch in the big round thing that floats. When this float drops, the switch should open and pump should shut off.
Make sure that the pump plug is plugged into the piggyback type float plug.
Jan 03, 2011 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Jun 04, 2010 | Dehumidifiers
Oct 31, 2009 | Genius Wayne Submersible Sump Pump With ...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
I have a simer pump 120 volt 60 hz 1/2 hp ser #70285 and the flot is getting stuck on and the pump wont shut off what can I do and where would I get a nother flot at
take a tie strap and readjust the float,, lower the float so it won't let the float get to the top of the pump or zip tie it to the pipe away from the pump,, you don't need a new pump or switch
May 16, 2009 | Simer 1/2 Hp Thermoplastic Submersible...
Pump runs too long
Install a float switch that will switch-off the pump once the water reaches its level.
Feb 23, 2009 | Genius Wayne Submersible Sump Pump With ...
Genius Wayne Submersible Sump Pump With  Switch Logo
Top Genius Electrical Supplies Experts
Steve
Gene Haynes
Are you a Genius Electrical Supply Expert? Answer questions, earn points and help others
