Question about Lexmark Office Equipment & Supplies
Lexmark s400 when copying, it won't copy full page only a small section even though it's set to letter size
2 Suggested Answers
  • 287 Answers
SOURCE: Lexmark X5100 printer. I copied
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Posted on Jul 12, 2008
MY hp laserjet 200 color m251 pcl 6 do not print full copy of A4 when printing via internet or wireless pls, i need a setting to make it print full copy . thank you.
I would check to ensure that the page size of both the driver and the printer are set to A4 and not letter. Most HP's will auto sub letter for A4 but if driver thinks paper is letter when it is actually A4 then the printout will not match.
Sep 16, 2016 | HP Color LaserJet Pro 200 M251nw
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
How do you make 8.5 x 14 copies on Lexmark Interpret S405 AllInOne
Please refer to the Lexmark S400 Series User's Guide from the Lexmark website for more detailed instructions on how to copy using your model.
I hope this helps.
Apr 09, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How do i change the size of print on my Lexmark pro250
Do you also get the same font size result when making a copy using the Copy button from the printer operator panel?
It could be due to the print setting on the application that you're printing from. e.g. If you are using Word application, go to File > Page Layout > select Fonts and choose your preferred font size.
Feb 25, 2012 | Lexmark Prospect Pro205 Wireless...
My Lexmark all in one won't scan the entire document. No matter what size setting I put it on (I get the 'most' scanned on Automatic, but it is still less than half the page.)
Do you get the same result when making a copy using the Copy button on your printer operator panel? Try to remove the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter. This will give enough time for the printer to reset itself. When the printer turns on, reinsert the cartridges. Load some paper and try to make a copy or scan again.
May 05, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
Prints gibberish
the pdf files you printed might be too small in letter size..check if the printer works properly if you copy and paste the adobe files in MS WORD and increase the letter size and then print it..pls feedback for this solution
May 22, 2009 | Lexmark Optra N 240 Laser Printer
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
3 Press Select.
All-In-One Center
4 Click Copy Now.
original.
Jul 12, 2008 | Office Equipment & Supplies
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
