Question about Frigidaire ATF6000ES Front Load Washer
Error "E 70" appears and the lights flash. Will not continue with the cycle. Have canelled and restarted but it stops and gives the same error notice.
  • Frigidaire Master
  • 19,396 Answers
Try first unplugging the appliance for five minutes and see if this can clear the error message.
Posted on Mar 12, 2009
  • Ginko
    Ginko Mar 12, 2009
    E70 is no cold water getting to the machine.
    If the message does not reset check the cold water faucet at the back of the machine.
    If still no luck then there is a faulty inlet valve.
    Let me know how it goes.
    Thanks.
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
Washing machine saying 3e starts a cycle then it stops and flashs 3e
The "E3" error indicates that a washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
A 3e error is a possible drain clog,Remove drain line and check for any clogs.
Apr 25, 2011 | Washing Machines
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
On the printer is say job canel then canel printing and now when i try printing something it dosnet print anymore and on the computer the status says error-printing
In run window type services.msc and the go to print spooler option just stop and restart the service.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Brother DCP-7020 All-In-One Laser Printer
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
When I turn lap top on Windows installer automatically atemps to execute a Sonic Upgarde Manager. uring the process there is reference to the Sonic installation package disk to locate UM.MS1. Upon...
to stop this
Go to Start >> Run >> type: msconfig (one dialog appears)
Select tab >> Start Up
UNCHECK the field where is located your "Sonic Upgrade Manager"
(Usually the path is like this:..(eg.) C:/Program files/.....your device.exe)
Hit >> Apply and then >> OK
This will be fixing your Pain.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
