Question about Roper REX4634KQ Electric Dryer
My dyer works but does not heat i put a innighter in already
It a roper model rgx5634kq2
  • 51 Answers
Most likely need to replace the heating coil which is probably cracked or broken
Posted on Mar 13, 2009
I have a Roper Dryer mod# Red4440VQ1 ser# my3678178 My prob is the dyer will not start unless it is in no heat mode. I think it's the timer Robert
sounds like the safty is keeping the unit from working check dryer vent for lint from outside to back of unit
Aug 27, 2011 | Roper Dryers
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
I have a Roper Gas Dryer, Model #RGX5634KQ2 it runs off propane. The dryer turns on and tumbles. It lights, heat comes on for just a minute then goes out. Clothes want dry
The problem sounds like the dryer coils are failing.They tend to fail as they heat up. These are very inexpensive and easy to fix. It could be several other things thermal fuse, thermal cut out, hi limit thermostat, heat sensor,or ignitor. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 04, 2010 | Dryers
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
heatman101
Mar 30, 2010 | Roper Dryers
My dryer turns on and heat fires up but only stays on for about ten min then shuts off Roper rgx5634kq2
the coils may be weak and not holding the valve open for the gas or you may have a weak ignitor. the ignitor should glow white hot not orange. hope this helps.
Oct 15, 2009 | Dryers
I have a 6yro roper gas dryer. model : rgx5634kq2 everything works except it wont heat up ignitor is good as well as thermal fuse
Hello, If your igniter is glowing does not mean it's good, Take a look at it while it is glowing..Is it orange in color..Uneven glow? then it's bad...the igniter needs to be pulling 3.5 amps in order for a) the gas valve to open B) gas to ignite once gas valve opens. The glow should be a brillient yellow that you find hard to look at. If the igniter is bad the only other possibilty is the flame sensor. It is the gadget hooked to the side of the tube where the flame is. Using an ohms meter disconnect the 2 wires from the terminals and check for condinuity..If you have no reading (condinuity) you should replace it. Good Luck!!! If you have any other questions or concerns please feel free to comment again. Mike
Jul 23, 2009 | Roper Dryers
How do i open the machine to get to the coil valve/ do i remove the blower wheel? and if so how is that done (roper mod# rgx4634jq0)
Here are the break down diagrams and Replacement parts for WHIRLPOOL RGX5634KQ2 |
AppliancePartsPros.com
Did you check the element?
Check if glow?.
also checked the continuity of the flame sensor.
If is good.
Am I to assume then that the heating element is bad? Or could there be another issue?
thia mean that the thermal fuse is bad.
You need to replace along with the cycling thermostat and see what happens.
"Did it solve your problem?"
Apr 18, 2009 | Roper RGX4634KQ Gas Dryer
Roper REX4634KQ Electric Dryer Logo
222 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
