Question about Briggs & Stratton Garden
Engine shuts off after about 10 minutes of use
Engine starts ok, but will shut off after about 10 minutes or so. it will start back up, but will only stay running for 10 or 15 seconds before it shuts off again. replaced fuel filter, and it appears the fuel pump is working.
tim from pa.
  • Anonymous Mar 23, 2014
    SOUNDS LIKE ITS STARVING FOR GAS EVERY 30-35 SECONDS
Try loosening the gasoline cap on the engine. My snowblower acted the same way until a mechanic told me it sounds like the engine is not getting enough air. Some gasoline cap vents go bad and starve the engine. If your engine continues to run you can buy a new gas cap.
Posted on Mar 13, 2009
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
I was driving my car pulled into the garage came back out the next day wont start, it cranks but thats it?????
Engine cranks - battery and starter ok. Check for fuel flow. I have seen fuel pumps go out like shutting off a light switch. Shut the car off and just 10 minutes later car will not start because fuel pump failed.
Jul 12, 2012 | 1998 Dodge Stratus
1996 honda accord starts up fine runs 10 15 minutes engine shuts down wait 5 ,10 minutes starts back up shuts off short time after
sounds like there could be a problem somewhere along the fuel line either between the pump and that engine or between the filter and the engine i have a car that would do the same thing turned out to be the fuel filter was full of **** ran like a dream after i changed that.
Jan 10, 2012 | 1996 Honda Accord
I have a 2005 Pontiac Grand AM and because of the security system it wont start, what do I do ?
most likely your key got erased from memory make sure you are using a chip key, in a 3 times 30 minutes put your key on (without starting the engine) and live it on for 10 minutes,shut it of and back on the same way for another 10 minutes,do it again 10 minutes more at the end shut it off wait 30 seconds and start the car,if it is not a brand new key it may take 1 or 2 times this sequence to get it to start. let me know
Aug 11, 2010 | 2005 Pontiac Grand Am
I have a 2000 s500 engine just shut off by itself
you need to have car scanned for codes and it sounds like it is due for a major service
Aug 30, 2009 | 2000 Mercedes-Benz S-Class
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Sep 26, 2008 | 1993 Chrysler Concorde
Just shuts off...problem continues
my mom has a 99 durango that did the same thing it would just stop running and would turn over but wouldnt start let it sit for a while then it would start right up it turned out to be the brain of the car the ecu dont know if this will help but its worth a shot
Sep 02, 2008 | 1999 Chrysler 300M
Garden Logo
417 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
