Question about Philips 190CW7CS27 Monitor
How to Adjust the sceen ratio from 16:9 to 4:3
When viewing pages in 16:9 ratio pages are strecthed so i would like to resize screen to 4:3 ratio but cant find it on the moniters menu or pc properties
  • Tom Lioumanis Aug 05, 2007
    Thanks nbanyan
    My settings tab only allows up to 1024x768.
    I think my s3 card wont allow 1440x900 after trying what you suggested.
    I may need a new s3 card????
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Posted on Aug 05, 2007
SOURCE:
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Full screen not displayed when viewing shot and playback
You mean that the image you take and playback is in 4:3 ratio. The default settings is 4:3. However, if you want to take widescreen (16:9 full LCD) images, just change the Image Size setting in the menu to 16:9 L (4288x2416 pixels) or 16:9 S (1920x1080 pixels). See the user manual page 30.
Oct 23, 2010 | Olympus SP800UZ Digital Camera
I recently bought a netbook and the internet screen takes scrolling to see the entire page...how can I resize?
This is due to the small resolution on netbooks.
If you cant adjust the resolution in the display options, you can adjust the text size on the browser page.
click on view/text size and try make the text size smaller(internet explorer)
or in firefox its Tools/options/content tab and adjust font size
Jul 10, 2010 | HP Mini 1035NR Notebook
I have a 42LG30 and the screen size is two big and I cant seem to find out how to manually resize it. The piture on the screen is two wide on the sides and the picture has a streched look as well
Ok just to clarify, your saying you use to be able to manually adjust the aspect ratio and now the option isn't available anywhere? and the setting doesn't exist in the manual? Are you sure it was a tv setting and not a setting for a device that was being output to the tv?
Thanks,
Lee
Jan 13, 2010 | LG 42LG30 42 in. LCD HDTV
Can only get "4:3" and "compressed 16:9" screen format. Want full "16:9" not compressed. How?
HDTV ready means that it will process HDTV signal to be viewed on you set. The size of your screen is still in a 4:3 ratio. Unless you have a true 16:9 size sceen you cannot get the full 16:9 picture. The actual physical size of the sceen is what makes TV's true HD or not. In other words, the screen has to be twice as wide as it is tall or 16:9. Your screen is almost square or 4:3. It can only show a compressed version of the 16:9. Thanks for using fixya.
Dec 13, 2009 | Philips 60PP9202 60" Rear Projection...
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
How do I move my screen image a few pixels to the left?
TV - analogue (S-Video, composite) X X X TV - analogue (component) X X VGA (with EDID) X X VGA (without EDID) X Digital (DVI, DisplayPort, or HDMI) X X Digital (HDTV via DVI, DisplayPort, or HDMI) X X LVDS (notebook display) X If the feature is supported, the corresponding tab is available on the Adjust Desktop Size and Position page. If only one feature is supported, then only the controls for that feature appear on the page and there are no other tabs.
Scaling The scaling controls let you adjust the size of the desktop to best fit your screen. The configuration that you specify may be overridden by the settings in the Resize section.
Select a scaling mode
Aspect ratio: This setting expands the desktop as much as possible while maintaining the same dimensional proportions, or aspect ratio, as the original image. There may be some black borders, but you may prefer this setting to avoid distorting the image.
Full-screen: This setting stretches the desktop to fill the entire display screen.
No scaling: This setting leaves the display image in its original size and centres it on your screen resulting in a small though crisp image. A black border may appear around the display image.
Perform Scaling on
GPU: This causes the GPU to scale the desktop from the set resolution up to the native resolution timing.
Automatic: This setting uses a combination of display and GPU scaling to scale the desktop from the set resolution up to the native resolution timing.
Override the scaling mode set by games and programs
When this check box is checked, applications cannot change the scaling mode set on this page.
Preview
Under the Preview section you can select a resolution and refresh rate, and then the preview image shows how full-screen applications will appear on the screen, using the selected scaling configuration. The available refresh rates will depend on the scaling method selected.
Resize Some displays, such as HDTVs, extend the edges of the display beyond the visible borders of the screen. This overscan is intended to hide broadcast data that is not intended for the viewer. This results in hiding useful parts of the screen for non-broadcast content, such as the Windows desktop.
The best way to resize the screen in order to view the entire content is to use the controls provided by the display hardware.
The resize controls on the NVIDIA Control Panel are provided in case satisfactory results cannot be achieved using the controls on the display.
Position Use the arrow buttons in the image under Adjust the desktop position to adjust the position of your desktop or image on your screen.
Aug 17, 2017 | Samsung SyncMaster 940BE 19" LCD Monitor
Screen resizing
hi, try changing the aspect ratio of the player to your suitable needs, commonly used ratio is 4:3.let me know
Jan 02, 2008 | Acer AL1916W 19" LCD Monitor
Philips 190CW7CS27 Monitor Logo
203 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
